At Time
Captures the value of a given solver expression at a given time.
Figure 1. Response Type – At Time
Input Description
Response Expression The solver expression that is to be computed.
Time The time point at which computation is desired.
Time Tolerance A small time interval around the desired Time required for computation.
In the above example, the response variable captures the value of the expression that measures rotation of a marker at time value of 1.2.
