Add a Response Variable
  1. From the Responses section of the Optimization Wizard, click the Add button.
    The Add Response Variable dialog is displayed.
  2. Click the System collector to choose the parent system for the RV.
  3. Specify a meaningful label and variable name.
  4. Click OK.
    Tip: Responses can also be added outside the wizard by right-clicking on Model (or any System) in the Project Browser and choosing Add > General MDL Entity > ResponseVariable.
