Outline
  1. If the Graphics panel is not currently displayed, select the desired graphic by clicking on it in the Project Browser or in the modeling window.
    The Graphics panel is automatically displayed.
  2. From the Connectivity tab, select an outline graphic type.
  3. Click the collector and select the marker, body, point, polybeam, or advanced joint associated with the graphic.
  4. Click the Properties tab.
    Note: The Properties tab only becomes available if you select Marker or Body/Point.
  5. Click Append to add additional markers, bodies, and points to define the graphic.
    Tip: Delete entities by selecting their respective check boxes and clicking Delete.
  6. Define the appended entities by clicking the collector and making your selection in the modeling window, or double-click the collector to display the Model Tree (from which the desired entity can be selected).
