Materials
Use the tool to view, add, and edit the material properties that are used for NLFE bodies.
Create and Edit Materials
Hyper Elastic Materials Overview
For hyper elastic materials, different constitutive material models are supported, such as: Neo-Hookean (both compressible and incompressible), Mooney-Rivlin, and Yeoh models that are used to model a hyper elastic NLFE Body.
Hyper elastic materials can undergo large deformations with a non-linear stress strain relationship.
The constitutive models for hyper elastic materials are characterized using the strain energy density function.
Type | Equation | Description |
Neo-Hookean Compressible | U=μ2(I1−3)−μlnJ+λ2(lnJ)2U=μ2(I1−3)−μlnJ+λ2(lnJ)2 | U - Strain Energy density function μ - Shear modulus I1−rTxrx+rTyry+rTzrz - rx, ry, and rz are the gradients of NLFE grids λ=2μv1−2v, is called the 2nd Lame's constant, v is the Poisson's ratio J=det(J)=rTx(ry×rz) |
Neo-Hookean Incompressible | U=μ2(ˉI1−3)+k2(J−1)2 | ˉI1=J−23I1 k=2μ(1+v)3(1−2v), bulk modulus |
Mooney-Rivlin | U=μ10(ˉI−13)+μ01(ˉI2−3)+k2(J−1)2 | μ01 and μ10 are material constants ˉI2=J−43I2 ˉI2=12((tr(C))2−(tr(C2))), where C is the Cauchy-Green deformation tensor C=JTJ J=[rxryrz] rxryrz are the gradient vectors |
Yeoh | U=C10(ˉI1−3)+C20(ˉI1−3)2+C30(ˉI1−3)3+k2(J−1)2 | C10, C20, and C30 are material constants |
The material constants for these models have to be derived through testing, such as: uniaxial, bending, and shear tests.
