Ground
Use the Ground tool to change a rigid body to a grounded state.
To change a rigid body to a grounded state:
  1. From the Geometry ribbon, click the Ground icon.
  2. Select bodies that are to be grounded. The grounded body will be highlighted in red.
  3. The body icon in the browser changes to .
  4. To un-ground, click again on the body.
Note: A default Ground Body exists in the model whose grounded state cannot be changed.
