Advanced Joints
Use the Advanced Joints tool to create and edit a set of special constraints called higher pair joints. Typically, these are constraints that involve a curve or surface on at least one of the two bodies.
Note: The connectivity and orientation information of a joint and bushing are identical. A joint places a combination of rigid constraints between two bodies, and a bushing places compliant constraints between bodies.
Table 1. Advanced Joint Constraints
Advanced Joint Type Removes Translational DOF Removes Rotational DOF Removes Total Number of DOF
Point to Curve 2 0 2
Curve to Curve 1 2 3
Point to Surface 2 3 5
Curve to Surface 2 3 5
Surface to Surface 2 3 5
Point to Deformable Curve 1 3 4
