IIHS Front (40%) Intrusion
Load a File
File type
Select the solver output results file type. Options include:
  • Radioss - TH
  • Radioss - A0
  • LS-DYNA - Nodout
  • LS-DYNA - binout
  • LS-DYNA - d3plot
  • H3D
  • Saved intrusion data
File name
Click the file browser icon to select the output result file for the selected file type.
Loaded files
This option retrieves the previously loaded files in the same instance of the session. Click the down arrow to see the files loaded currently.
Time History in Ref Coordinate System
For time history files (nodout, binout, TH):
  • Selected results file is validated for the selected file type.
  • All node (response location) selection drop-down fields will be filled with the response location/node available in the result file.
Intrusion with Seat Correction
Subtracts the displacement of the seat mounts from the displacement values at the target intrusion points so that the new intrusion values will be free of any errors due to any deformations after the seat. All values are first calculated based on the reference coordinate system and then seat corrections are made. This correction helps to determine exact values of intrusions faced by the occupant.
Align with Global T = 0
Activating this option aligns the local system with global at the first animation frame when Time = 0 and performs the intrusion calculations.
Dynamic Max
Enables the calculation for every point individually for its maximum deformation out of all simulation steps instead of reading only the final timestep.
Ref coordinate system
This option resolves displacement with respect to the local system. If displacement is resolved in the results file, then intrusion should be calculated without resolving displacement.
Origin
Select nodes for the d3plot and H3D files.
Click the arrow, , to pick nodes from drop-down menu. For animation files, node numbers can be typed in.
Nodes can be selected from drop-down menu for nodout, binout, and TH files. For example:
Seat mounts
The seat mount inputs (front right/left and rear right/left) are activated after selecting Intrusion of Seat Correction. Please select the respective Time History channel for coordinates of the node at the respective positions. In case of animation files, the node can be picked from the screen. Thus, this input needs to be:
  1. Requested from the solver for time history files (T01, nodout, binout)
    Or
  2. Picked on the screen for animation files (H3D, A01, d3plot)
Measurement points
Select the node ID for each measurement point listed. Locations include:
  • A Pillar
  • B Pillar
  • Brake Pedal
  • Dash Center
  • Dash Left
  • Dash Right
  • Foot Rest
  • IP Left
  • IP Right
Curve Options
Allows you to edit the following curve display options:
Title
The curve name.
Mode
The standard modes available to plot curves. From the drop-down menu, select Append, Overlay or Replace.
Style
Select the curve line style.
Width
Select the curve line width.
Color
Select the curve line color from the palette.
Additional Points
Click to display the Additional Measurement Points dialog, where you can pick the location and node ID for additional points.
Load/Save defaults
User-specified inputs can be saved as a default file (.def) and can be loaded again for future use. Reference coordinate system points, seat mount points, measurement points and curve options are saved in the default file.
Export Intrusion
Exports the last calculated intrusion values into a text file. An exported intrusion text file can be reused later by selecting Saved intrusion data as the file type and selecting the respective file.
For plotting saved intrusion data, you can directly select the file, specify curve options, and plot the graph.
Apply
Upon clicking Apply, the following steps are performed to plot the final results:
  • Validate inputs.
  • Calculate intrusion for all measurement points.
  • Plot the intrusion plot with standard regulation limit plots. Intrusion values are also tabulated in a separate TextView window.
