Define Constraints
Create Single Point Constraints (SPCs).
Using the Constraints too, you can define a constraint at a node and assign it to a loadstep in the model.
  1. From Setup group, select Define Constraints.
    A guide bar will appear.
  2. Select node(s) where the constraint should be created in the graphics area.
  3. Select required Load Steps.
  4. Select the degree(s) of freedom.
  5. Click .
    This creates a single point constraint (SPC) at the selected node(s). The newly created SPC will be assigned to the selected loadstep.
Define Constraints Options
Description of Setup Constraints options.
Constraints Type
SPC- Single Point Constraint
Load Steps
Select required loadstep present in the model.
You will have to create an event before creating a SPC.
Degree(s) Of Freedom
- Translation along X, Y and Z
- Rotation about X, Y and Z
