Create E-Lines
Use Create E-Lines tool to create evaluation lines at component interfaces.
- Fast Create
- Use to create many E-Lines at a time to get quick and approximate overview of squeak and rattle risk zones.
- Manual Create
- Use to manually create one E-Line at a time and control the setup to ensure the accuracy in analysis results.
Fast Create
Manual Create
Create E-Lines Options
Spacing: Value for the spacing between two adjacent Evaluation Points on an E-Line
Search Distance: Value for search / gap tolerance between the selected master-slave component
Gap Direction: Realization Projection direction, controls creation of the local coordinate systems which determines the Gap Direction
Figure 3. Zdirection will be perpendicular or Normal to Master component.
In Plane to Master
Figure 4. Z direction will be In Plane to Master component.
Contact Types: Defined Contact type for this E-Line, this is based on Youngs' modulus value of the Master and Slave FE Material.
to open edit E-line
definition parameters under
