poIResultMathCtrl SetLabel
Sets the label of the result math expression.
rmathexp_handle SetLabel label
HyperView Tcl Modify
This command sets the label of the result math expression.
label
The label for the expression. The label cannot be the name of an existing data type. In addition, the label cannot contain any of the following characters: '[',']','{','}','\'','\','<','>','&', ':'.
To set the label of the result math expression:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis “c:/samples/bumper/d3plot” “c:/samples/bumper/d3plot”]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set eid [rmath_handle AddExpression]
rmath_handle GetExpressionHandle expr_handle $eid
exp_handle SetLabel "myexpression"
hwi CloseStack
Returns a non-zero value if there is an error.
