poIResultMathCtrl GetOperatorSyntax
Returns the syntax of the operator as used in the Expression Builder.
rmath_handle GetOperatorSyntax lib oper
HyperView Tcl Query
This command returns the syntax of a result math operator.
lib
The name of the result math library.
oper
The name of the result math operator.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis “c:/samples/bumper/d3plot” “c:/samples/bumper/d3plot”]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
rmath_handle GetOperatorSyntax math log
hwi CloseStack
Returns an empty list if an error occurs.
