poIResultMathCtrl GetOperatorArgumentCount
Gets the number of arguments for a particular result math operator.
rmath_handle GetOperatorArgumentCount lib oper
HyperView Tcl Query
This command retrieves the number of input arguments needed for a result math operator. A result math operator is a part of a result math library. For operators in a plugin library, the number of arguments is always one.
lib
The name of the result math library.
oper
The name of the result math operator.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis “c:/samples/bumper/d3plot” “c:/samples/bumper/d3plot”]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set argcount [rmath_handle GetOperatorArgumentCount math +]
set argcount [rmath_handle GetOperatorArgumentCount math sqrt]
set argcount [rmath_handle GetOperatorArgumentCount model area]
hwi CloseStack
Returns -1 if there is an error.
