poIImagePlane ReprojectionError
Calculate the reprojection error between the current multi-point alignment points.
Imageplane_handle ReprojectionErrors pointList
HyperView Tcl Query
This command returns a calculation (float) of the projection error that would result from an alignment based on the point list.
pointList
A string containing at least seven corresponding model and image points that will be used for an alignment.
The string is in the following format: # of points, model node locator strings, x y image points. This is the same format that is returned from GetAlignmentData when the alignment mode is set to IP_MULT_POINT.
To determine if the sync scale has been modified:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetFileName “some file”
image_plane_handle ReprojectionError "9  1 420608 @ 1 225 1 608  1 420840 @ 1 225 1 840  1 420314 @ 1 225 1 314  1 409148 @ 1 160 1 1148  1 438182 @ 1 159 1 182  1 391833 @ 1 183 1 4833  1 429052 @ 1 134 1 52  1 349822 @ 1 186 1 2822  1 409119 @ 1 160 1 1119 186 164 55 215 315 255 476 266 558 380 637 344 339 380 578 297 475 170 "
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid, or HW_InvalidArgs if the invalid point list is passed.
