poIImagePlane GetAlignmentPointList
Gets information about an alignment point.
Imageplane_handle GetAlignmentPointList pt_idx
HyperView Tcl Query
This command queries information about an alignment point.
pt_idx
The index of the alignment point to be queried. Index starts at 0.
The following example adds three alignment points and queries the second point:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
# Add 3 alignment points
imageplane_handle AddAlignmentPoint
set ipdata [imageplane_handle GetAlignmentPointList 1]
puts “Model Node is [lindex $ipdata 0]”
puts “Image point is [lindex $ipdata 1] [lindex $ipdata 2]”
hwi CloseStack
None.
