poIImagePlane RemoveAlignmentPoint
Removes an alignment point from an image plane.
Imageplane_handle RemoveAlignmentPoint idx
HyperView Tcl Modify
This command removes an alignment point from an image plane.
idx
The index of the alignment point to be deleted. Index starts at 0.
The following example adds three alignment points and deletes the second point:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
# Add 3 alignment points
imageplane_handle AddAlignmentPoint
# Remove alignment point 2 (index is 1)
imageplane_handle RemoveAlignmentPoint 1
puts “Alignment point count is [imageplane_handle GetNumAlignmentPoints]”
hwi CloseStack
None.
