*repeatcounter()
Specifies a counter to store the current repeat value for a *beginrepeat() or *beginrepeat2d() command.
*repeatcounter (counter number)
HyperMesh Card Previewer Command
counter number
An integer value between 1 and 20 indicating which of the 20 possible counters should be hold the current repeat value.
