*menucase()
The *menucase() command specifies a block of card image template commands that are executed when an attribute has the value matching the *menucase() command.
*menucase (value)
HyperMesh Card Previewer Command
value
Must be an integer value.
*menucase() commands must occur in consecutive, incremental order.
The values 0 and 1 are the only legal values for a *menuoption() command.
The values 1 to N are legal for a *menuoptionenum() command where N is the number of values in the enumeration referenced by *menuoptionenum().
