*menuentitytype()
Modifies an attribute field so that the selection must be an ID of an entity of a specified type in the HyperMesh database.
*menuentitytype (entity_type)
HyperMesh Card Previewer Command
entity_type
entity_type must be a valid HyperMesh entity type.
The *menuentitytype() command cannot modify a *menufield() along with a *menuenum(), a *menurestrictedvalue() , a *menulegalvalue() , or a *menudefaultvalue() command.
This command follows a *menufield() command that references an entity attribute. This changes the appearance of the field in the card previewer to a collector of the specified type.
