*globaldefaults()
Used to specify that each real, integer, and string attribute is modified as per the *menudefaultvalue().
*globaldefaults ()
HyperMesh Card Previewer Command
Any default value not overridden by a *menudefaultvalue() fills the field with the number of blanks equal to the width parameter in the *menufield() command when the field has the status off. *menudefaultvalue() can still be used to specify a different default value for individual fields when needed.
