*menuif()
Used to conditionally execute branches in the card image.
*menuif (expression)
HyperMesh Card Previewer Command
expression
A relational expression.
Requires an *menuendif() command.
The expression is required to be enclosed in square brackets.
The following operators are available:
==, = equal
!= not equal
<= less than or equal
< less than
>= greater than or equal
> greater than
If multiple entities are being displayed and an *menuif() returns conflicting results for the expression, the entire *menuif()/ *menuelse() / *menuendif() block is skipped.
