Control the Display State of Weld Lines
Show, hide, and isolate weld lines.
From the weld line browser, right-click on a weld line and select a display option.
For Show and Isolate, the following options are available:
Weld
Show/isolate the weld only.
Weld + Comp
Show/isolate the weld and any attached components.
Weld + Systems
Show/isolate the weld and the systems of each weld segment that make up the parent weld.
