Select Weld Lines Graphically
In addition to picking from a list, weld lines can also be selected graphically using the weld line browser.
  1. Click in the weld line browser.
    Note: This feature is only available in the Mark Welds and Points tools.
  2. Use the entity selector to pick weld line components from the modeling window.
  3. Click .
    The selected weld lines are highlighted in the browser.
    If Components other than welds are selected, they will automatically be excluded.
