Delete Weld Lines
Remove weld lines from the model.
Delete weld lines in the following ways:
  • From the HyperLife Model Browser, select a weld line and press Delete, or right-click and select Delete from the context menu.
  • From the weld line browser, right-click on a weld line and select Delete from the context menu.
  • In the Mark Weld dialog, select weld lines then click .
