Job Manager
Job Manager is designed to provide a way to interact with analysis jobs created through the NVH Director.
To invoke the Job Manager, click the icon.
Job Manager Toolbar
Job Import and Path Check |
Job Export |
Job Path Check |
Delete an existing job record |
Re-run a job |
Stop a running job |
Update the job list |
Select all jobs in the table |
De-select all jobs |
Select those jobs not previously selected |
Show the log window |
Opens the Filter jobs dialog |
Job Table
- Job Names
- Name of the analysis defined in the Analysis Manager.
- Job Number
- Job sequence ID.
- Job Submission server
- Server to which the job was submitted to.
- Application
- Solver that was used to perform the analysis.
- Job Directory:
- This is typically the directory where the input .xml file is located.
- Input File Name
- NVH Director model .xml file.
- Status
- Job completion status.
- Created Date
- The date a job was created or modified.
Job Details
Result Files
