HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
NVH analysis is a special form of physical analysis where the understanding of motion, energy and force transfer are the
primary means of root cause identification and problem solving.
Set parent modules with CMS SE representation in H3D format to be used for analysis in lieu of child module representations
when rolled up, or use the child representations when rolled down.
To manage any of the modules shown in the Assembly Browser, right-click on a module and select Edit Representations. This opens the Edit Module tab, and the Representation sub-tab is shown.
Create panel sets by selecting nodes/elements and/or existing node sets in the model file, that will automatically be
used in setting up Panel Participation diagnostic output in NVH analysis.
In a real-life application, necessary preparation work needs to be done to get the module representation files to a state
that is ready for assembly. Use the Prepare Module tool to accomplish this goal.
Edit and test NVH templates used for creating lumped parameter (LP) models, multiple instances of one model transformed
to a new geometric location, or loadcases.
An Analysis is a collection of model configuration, analysis loadcase and analysis set-up selections that completely specifies
the assembly definition for a particular loadcase simulation event.
Package all project data (Assembly .xml files, Representation files, LP Templates, Loadcase files, Job files and CSV templates) for transfer to others or for
archival.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
shown.
Managing Representations
A module representation is simply a way a module can be represented. Valid representation
types can be assigned using the Type drop-down menu and include:
CAVITY
A finite element model that contains only fluid elements.
CMS
An H3D or OP2 based component modal synthesis model.
CDS
An H3D based component dynamic stiffness model.
An option to convert test FRFs in UNV format to CDS H3D and define it as module
representation.
FE
Typical detailed finite element models.
DMIG
DMIG based model files in ASCII format.
FRF
A model containing frequency response functions.
LP
A lumped parameter model is a simplified 1D finite element model that represents
dynamic behavior a more details model.
MODAL FE
A finite element modal model that contains spring/damper/spoint/mpc elements.
PLOT FE
A finite element model that contains PLOTEL, PLOTEL3 and PLOTEL4 elements.
Right-clicking the white space will give you the options to add, remove, or edit the
description of the selected representation.
A file assigned to the root representation can be optionally auto-assigned to be a Display
representation (PLOTFE type) simultaneously by checking the Assign file to Display
representation checkbox.
A representation can be auto-selected to be the Display representation by checking the Set
as Display, load and extract TagPoints checkbox. This will be followed by the file being
imported into the 3D graphics window and TagPoints defined in the file extracted.
Once all representations are defined, click the Assembly Browser tab to
review the assembly hierarchy with active Display and Analysis representations.
Define Test FRFs (UNV) as module representations
An additional option in CDS-SE allows you to read UNV files that have test FRF information
and convert them into a CDS-H3D file. This can then be assigned as module representation.
Modal model review and parameter modifications
These features allow for the review of modal model parameters of reduced model
representations (both CMS-SE and Modal-FE) and modifying them. This will help you in
understanding the effect of changing these parameters on NVH responses, without
generating reduced models with necessary modifications.
The related list of features for CMS-SE are:
Validate SPOINT ids
Allows you to manage ID conflicts between SPOINT IDs of CMS-SE reduced model
and module ID ranges.
Assign damping
Assign existing damping/add component damping to existing damping in CMS-SE.
By default, existing damping while creating CMS-SE is used. There is also an
option for adding damping to existing component damping.
Modal parameters review and modification: Use the ascii option to read modal
parameters information from an .ascii file
(_dmig_dv.inc) generated during the CMS-SE solver run.
Information related to the modal is populated for review. Select Mode to modify the
parameters. This will activate the Edit fields to modify frequency and damping values.
There is also an option for the mode to be Grounded. Save and apply the changes. This
modified information is then exported to the solver deck.
Figure 3.
Figure 4. Clicking Validate SPOINT IDs Opens this Dialog
Figure 5. Clicking Assign Damping Opens this Dialog
Figure 6.
Figure 7. Clicking the icon Opens the Create/Edit
TABDMP1 Dialog
For Modal-FE, modal parameters are populated on loading the representation file. The
options for review and modifications of parameters are the same as for CMS-SE.
Figure 8.
Managing Tagpoints
A Tagpoint is a special point used in the assembly for connection, input, response and plot
purposes. It consists of a grid with a set of relevant properties, such as name, description
and dependency.
Figure 9.
Tagpoints are displayed in the 3D graphics area and can be customized via the NVH Module
Display toolbar. By default, tagpoints are indicated with a gray sphere along with the
label. Other options are available using the pull-down menu.
Figure 10.
To add a tagpoint, right-click inside the tagpoint list in the Tagpoint tab and select
Extract All to extract TagPoints from the
comments added to the 10th field of the grids in the loaded Display model.
Lock ID
Lock ID’s provide you with a means to maintain the ID’s of tagpoints without getting
renumbered by locking them. This prevents accidental renumbering of tagpoints.
Lock ID’s have a higher preference than the sub ranging utility. If ID’s are locked
for tagpoints, then sub ranging will not renumber those locked ID’s in Prepare Module
mode.
This utility can lock the ID’s of existing tagpoints using edit tagpoints or it can
lock the tag ID while creating it using the Create TagPoints utility.
Figure 11. Locking ID's of Tagpoints as and When They are Created
Figure 12. Locking ID's of Existing Tagpoints
Figure 13. Locking ID's of Tagpoints Through the Tagpoint Mapping Tool
ID Tab
Sub ranging
Sub ranging provides you with a means to reserve a range so that it is not occupied
and not referred by anybody. This is primarily needed if you want to reserve a certain
ID range for a specific use and should not be occupied by other entities.
Some customers follow a convention of reserving the first 10,000 ID’s of nodes for
connections for every include. They would like to reserve them at the start and then
allocate these ID’s to the tagpoints pertaining to respective includes, by releasing the
reserve range, when it is required.
Figure 14.
The following images show a sample file with and without sub ranging.
