Anisotropic Layered Medium
This option defines an anisotropic layered medium by specifying the label of the material to be used for each layer.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_dl2.png)
Figure 1. The DL - Define layered medium properties dialog set to Anisotropic layered medium.
Parameters:
- Number of layers
- The number of anisotropic layers defined for the layered medium.
- Thickness of this layer
- The thickness of the current layer in m (if an SF card is present, this is always scaled).
- Angle of principal direction
- The angle (in degrees) from which the principal direction is obtained.
- Material in principal direction
- The material label of the material to be used in the principal direction.
- Material in orthogonal direction
- The material label of the material to be used in the orthogonal direction.
