Isotropic Layered Medium
This option defines an isotropic layered medium by specifying the label of the material to be used for each layer.
Parameters:
- Number of layers
- The number of isotropic layers defined for the layered medium.
- Thickness of this layer
- The thickness of the current layer in metres (if an SF card is present, this is always scaled).
- Material label (dielectric)
- The label of the material to be used for the current layer (as defined in the DI card).
