createSphericalJoint
Modeling FunctionDefines a spherical joint between two bodies.
createSphericalJoint creates the I and J marker and returns the joint object created. All properties of a spherical joint are supported by keyword arguments.
Signature
joint = createSphericalJoint(ibody, jbody, location=None, **kwds)
Input Arguments
ibody
The first body on which the joint is created.
jbody
The second body on which the joint is created.
location
The location where the joint is created.
kwds
Keyword arguments that define other properties on the joint.
Return Value
joint
The spherical joint created.
Usage
# Create a spherical Joint at (1,1,1)
part1 = Part(mass=1, ip=[10,10,10], cm=Marker())
part2 = Part(mass=1, ip=[10,10,10], cm=Marker())
     ibody = part1,
     jbody = part2,
     location = Point(1,1,1),
