Model ElementCoupler defines an algebraic relationship between the degrees of
freedom of two or three joints. This constraint element may be used to model idealized spur
gears, rack and pinion gears, and differentials as simple constraints that relate the
displacements in a set of joints.
Attribute Summary
| Name |
Property |
Modifiable
by Command? |
Designable? |
| id |
Int
| label |
Str
| Types |
"T
R" |
| joints |
Reference ("Joint", count=3) |
| type |
EnumString (Types, count=3) |
| scales |
Double ([1,0,0], count=3) |
FD Only |
| function |
Function ("COUSUB", xxfunc="COUXX", xx2func="COUXX2") |
| routine |
Routine () |
| script |
Script () |
| active |
Bool () |
Yes |
| virtual |
Bool () |
Yes |
Usage
#1: Linear coupler specified in the input deck
Coupler (joints=list, scales=list, optional__attattributes)
#2: Nonlinear coupler specified in a user-written subroutine in compiled DLL
Coupler (joints=list, function=userString, routine=string, optional_attributes)
#3: Nonlinear coupler specified in a Python function
Coupler (joints=list, function=userString, routine=functionPointer, optional_attributes)
Attributes
- joints
- List of references to joint objects.
- joints specifies a list of joints (j1, j2, and so on)
whose internal degrees of freedom are to be coupled with a
COUPLER. The list must contain at least two
joints. A maximum of three joint freedoms may be coupled.
- This attribute is required.
- Only revolute, translational, and cylindrical joints may participate in
a COUPLER.
- scales
- List of doubles.
- Defined as the scale factors to be used when defining the constraint
associated with a coupler.
- When only two joints are used to specify the coupler constraint, the
ratio is given two real values.
- When three joints are used, the ratio must be provided with three real
values.
- This attribute is optional.
Note: The attribute
scales is exclusive to the attribute
function. scales may not
be defined when function is defined and vice
versa. However, one of the two must be specified.
- joints
a COUPLER.
- function
- The list of parameters that are passed from the data file to the user
defined subroutine.
Note: The attribute
function is exclusive to the attribute
scales. function may not
be defined when scales is and vice versa.
- routine
- String
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by "::". The first is the
pathname to the shared library containing the function that computes the
response of the user-defined Variable. The second is
the name of the function in the shared library that does the
computation.
For example: routine="/staff/Altair/engine.dll::myCoupler"
- "/staff/Altair/
engine.dll is the dll
- "myCoupler" is the
function within this DLL that performs the calculations
- The attribute routine is optional.
- When not specified, routine defaults to
COUSUB.
- joints
- joints specifies a list of joints (j1, j2, etc.)
whose internal degrees of freedoms are to be coupled with a
joints. A maximum of 3 joint freedoms may be coupled.
a COUPLER.
- function
defined subroutine.
Note: The attribute
be defined when scales is, and vice versa.
- routine
- Pointer to a callable function in Python.
- For example: routine=myCousub
- myCousub is a Python
function or method that can be called from wherever the model
resides.
COUSUB.
Optional attributes - Available to all variants
- type
- List containing the string "T" or
"R".
- type defines a list that describes the freedom type
that is being used for each of the joints.
- "T" indicates that the translational degree of freedom
in the joint is to be used.
- "R" indicates that the rotational degree of freedom in
- This attribute is optional, unless one of the joints is a cylindrical
joint. In this case, the length of the types list
must be the same as the length of the joints
list.
- label
- string
- The name of the COUPLER element.
- This attribute is optional. When not specified, MotionSolve creates a label for you.
- id
- Integer
- Specifies the element identification number for the
COUPLER. This number must be unique among all the
COUPLER objects in the model.
- This attribute is optional. MotionSolve
automatically creates an ID when one is not specified.
- Range of values: id > 0
- active
- Bool
- Select one from TRUE or FALSE.
- TRUE indicates that the element is active in the model and it
affects the behavior of the system.
- FALSE indicates that the element is inactive in the model and it
does not affect the behavior of the system. It is almost as if
the entity was removed from the model, with the exception that
can be turned "ON" when desirable.
- The attribute active is optional. When not specified,
active defaults to TRUE.
- virtual
- Boolean
- Defines whether the constraint is virtual or regular. Select
"TRUE" or "FALSE".
- “TRUE” indicates that the constraint is
implemented as a virtual constraint.
- “FALSE” indicates that the constraint is
implemented as a regular algebraic constraint.
Optional. When not specified, virtual
defaults to “FALSE”. For a more detailed
explanation about virtual, see Constraint: Joint.
Examples
- A linear COUPLER connecting a revolute and translational
joint.
jt1 = Joint (label="Joint-1", i=i1, j=j1, type="REVOLUTE")
jt2 = Joint (label="Joint-2", i=i2, j=j2, type="TRANSLATIONAL")
Coupler (label="Coupler-0", joints=[jt1, jt2], type=["R", "T"], scales=[1, 2.5])
- A linear COUPLER connecting a revolute, translational, and
cylindrical
joint.
jt3 = Joint (label="Joint-3", i=i3, j=j3, type="CYLINDRICAL")
Coupler (id=2, label="Coupler-2", joints=[jt1, jt2, jt3], type=["R", "T", "R"], scales=[1, 2.5, 3.7])
- A nonlinear COUPLER with default routine names connecting two
translational
joints.
trans1 = Joint (label="Joint-2", i=i2, j=j2, type="TRANSLATIONAL")
trans2 = Joint (label="Joint-2", i=i2, j=j2, type="TRANSLATIONAL")
Coupler (label="Coupler-3", joints=[trans1, trans2], type=["T", "T"], function=user(1,2,3))
See Properties for an explanation
about what properties are, why they are used, and how you can extend these.
For a more detailed explanation about Couplers, see
Constraint: Coupler.
- For a more detailed explanation about virtual, see
Constraint: Joint.
