Model ElementThe
Frustumelement allows you to represent the portion of a cone that
remains after its upper part has been cut off by a plane parallel to its base, or that is
intercepted between two such planes.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| end_caps |
Enum
("OPEN CLOSE TOP_ONLY BOTTOM_ONLY") |
No |
| cm |
Reference(Marker) |
Yes |
| top |
Double() |
Yes |
| bottom |
Double() |
Yes |
| length |
Double() |
Yes |
| refinement_level |
Int() |
| material_inside |
Bool
| color |
String() |
| hidden |
Bool() |
No |
Usage
Frustum(curve=Marker(), top=120, bottom=50, length=200)
Attributes
- end_caps
- Enum()
- This property allows you to control the appearance of the cylinder. Four
options are available:
- OPEN
- CLOSED
- TOP_ONLY
- BOTTOM_ONLY
- cm
- Reference(Marker)
- The marker is used as a coordinate system for the frustum graphic. It
represents the center of the bottom circular section at the base of the
frustum.
- bottom
- Double()
- The radius of the bottom circle of the frustum graphic.
- top
- Double()
- The radius of the top circle of the frustum graphic.
- length
- Double()
- The length of the frustum graphic.
- refinement_level
- Int()
- Specifies the level of detail of the frustum geometry. Default is 2.
- material_inside
- Specifies if the graphic has material inside or outside. material_inside
is a boolean flag (True/False).
- True means the geometry is solid. In other words, it is
filled with material and its exterior is devoid of material.
Consequently, the surface normals of the geometry point outward.
- False means the converse: The exterior of the geometry
is filled with material and the interior is devoid of material. In this
case, the surface normals of the geometry point inward.
- color
- String()
- The color of the graphic for H3D animation. Specified as RGB (Red :
Green : Blue).
- hidden
- Boolean
- Specifies weather the graphics is being written to the H3D file or
not.
- True implies that the graphic is hidden and is
not written to the H3D file.
- False implies that the graphic is not hidden
and is written to the H3D file.
- This attribute is optional. When not specified, it defaults to
False.
Example:
Define Frustum
geometry
Frustum (cm=Marker(), top=120, bottom=50, length=200)
- See Properties for an explanation about what properties are, why they
are used, and how you can extend these.
