ParamSurface
Model ElementThe ParamSurface element allows you to represent a surface defined in the model as a Surface element.
Class Name
ParamSurface
Attribute Summary
Name Property Modifiable by command? Designable?
surface Reference (Surface) No
rm Reference (Marker) Yes
U_seg Int ()
V_seg Int ()
color String()
hidden Bool() No
Usage
surface = ParamSurface(rm=Marker(), surface=Surface(), seg=20)
Attributes
surface
Reference (Surface)
The surface entity represented by this graphic object. This attribute is mandatory.
rm
Reference (Marker)
The Coordinate system with respect to which the surface is defined.
U_seg
Int ()
Specifies the number of line segments used to represents the Surface in the U direction.
V_seg
Int ()
Specifies the number of line segments used to represents the Surface in the V direction.
color
String()
The color of the graphic for H3D animation. Specified as RGB (Red : Green : Blue).
hidden
Boolean
Specifies weather the graphics is being written to the H3D file or not.
  • True implies that the graphic is hidden and is not written to the H3D file.
  • False implies that the graphic is not hidden and is written to the H3D file.
This attribute is optional. When not specified, it defaults to False.
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
