Curve
Model ElementCurve defines a parametric curve in 3D space.
Class Name
Curve
A parametric curve has one free parameter, u, and three associated functions f(u), g(u) and h(u). For every value, u=u*, f(u*), g(u*), and h(u*) represent the coordinates of a point in space. As u is swept from its minimum to maximum value, a curve in 3D space is generated. For additional information on the definition of Curve, please see the Description and the Comments section of Reference_ParamCurve.
Attribute Summary
Name Property Modifiable by command? Designable?
id Int ()
label Str ()
matrix Reference ("Matrix") Yes FD Only
curve_points Bool () Yes
closed Bool () Yes
minpar Double (-1.0)
maxpar Double (1.0)
routine Routine ()   FD Only
script Script ()
function Function ("CURSUB")   FD Only
Usage
Curves are available in three different forms.
#1: Curve data provided in a Matrix
Curve (matrix=objMatrix, type=string, curve_points=Boolean, optional_attributes)
#2. Curve specified in a compiled user-written subroutine
Curve (function=userString, routine=string, type=string, optional_attributes)
#3. Curve specified in a Python functionCurve (function=userString, routine=functionPointer, type=string, curve_points=boolean, optional_attributes)
Attributes
matrix
Reference to an existing matrix object.
Specifies the Matrix that contains the curve data. The matrix should contain only the x-, y-, and z- data for the individual curve points.
Note: For a closed curve, the first and last data points must be the same.
The matrix attribute is mandatory.
type
String
Select from "OPEN" or "CLOSED".
The type attribute is mandatory.
curve_points
Boolean
Select from TRUE or FALSE.
  • TRUE means that the curve passes through the points.
  • FALSE means that the curve (B-spline) stays close to the points, but does not pass through them in general.
The curve_points attribute is mandatory.
function
String
The list of parameters that are passed from the data file to the user-defined subroutine.
The function attribute is mandatory
routine
String
Specifies an alternative name for the user subroutine. The name consists of two pieces of information, separated by "::". The first is the pathname to the shared library containing the function that computes the response of the user-defined Surface. The second is the name of the function in the shared library that does the computation.
An example is: routine="/staff/Altair/engine.dll::myCurve"
  • "/staff/Altair/ engine.dll is the dll
  • "myCurve" is the function within this DLL that performs the calculations
The attribute routine is optional.
When not specified, routine defaults to CURSUB.
type
String
minpar
Double
Specifies the minimum value of the curve parameter.
The minpar attribute is optional. When not specified, it defaults to -1.
Note: When specified, minpar < maxpar.
maxpar
Double
Specifies the maximum value of the curve parameter.
The maxpar attribute is optional. When not specified, it defaults +1.
function
String
routine
Pointer to a callable function in Python.
An example is: routine=myCurve"
  • myCurve is a Python function or method that can be called from wherever the model resides.
type
String
minpar
Double
maxpar
Double
Optional Attributes - Available to all description methods
id
Integer
Specifies the element identification number. This number must be unique among all the Surface objects in the model.
This attribute is optional. MotionSolve will automatically create an ID when one is not specified.
Range of values: id > 0
label
String
Specifies the name of the Surface object.
This attribute is optional. When not specified, MotionSolve will create a label for you.
A cycloid is defined in parametric space as:
x = a * (t - sin(t))
y = a * (1-cos(t))
"t" is the independent parameter. The cycloid is shown in the image below.
Figure 1. A parametrically defined cycloid curve
  1. Define a parametric curve using a matrix.
    The statement defining the cycloid described above has the following curve attributes:
    • The Curve is open
    • The independent parameter t starts at zero
    • The independent parameter t ends at 5
    • The curve points are specified in the Matrix object mat23
    The corresponding MotionSolve Python specification is:
    # Note, since curve_points=True, MINPAR=-1 and MAXPAR=+1.
    # This range in u will accommodate all the data provided in the matrix.
    curve1 = Curve (type="OPEN", curve_points=True, matrix=mat23)
  2. Define a parametric curve in a python function.
    This example shows how to specify exactly the same for implementation in a user-defined subroutine written in Python:
    # The cycloid function saved in file: cycloid.py
    from msolve import sin, cos
    def cycloid (id, par, npar, t, iord, iflag):
       a = par[0]
       if iord == 0:
          y = a * (1 - cos(t))
          z = 0.0
       elif iord == 1:
          x = a * (1 - cos(t))
          y = a * sin(t)
          z = 0.0
       else:
          x = a * sin(t)
          y = a * cos(t)
          z = 0.0
       return [x, y, z]
    curve2 = Curve (function="USER(1)", routine=cycloid, type="OPEN", minpar=0, maxpar=6)
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
  2. For a more detailed explanation about Curve, see Reference: ParamCurve.
