PAM-CRASH 2G Interface 2021.2 Release Notes
PAM-CRASH Interface
New Features
- Exported decks formatting
- The quality of the exported solver decks is improved with the writing of all solver keywords field names.
- Include organization
- The Organize context menu option is now made available for all entities. Furthermore, the organization of entities into an include file has been improved to automatically consider all references linked to the selected entities. This feature is also available performing drag and drop of an entity into an include file.
- Drive Mapping
- On import of solver decks that contain includes, HyperWorks now allows mapping from one folder path to another to import include files where the include path written in the solver deck doesn’t match the location of the files. This includes different paths due to different operating systems. Found in Preferences → Drive Mapping, or in the Solver Deck import options, you can define the source path where the files reside, and the target path as written in the solver deck, and use this to successfully import files without the need to edit the include paths in a text editor.
- New Keywords
- MATER 240 (Material Type 240 - Muscle) and MATER 241 (Material Type 241 - Muscle-Tendon)
Enhancements
- Intersections and Penetrations Check Tool
- The algorithm is improved with following enhancements:
- Updated Keywords
- PLY Type 0 (ITYP = 0) and PLY Type 1 (ITYP = 1)
Resolved Issues
- Added improvements to LOOKU keyword for ARGUMENT and FUNCTION while create, edit, and plot dynamically.
- Older options Apply Initial Metric, which are no longer valid, are removed from the list as the new Reference Geometries entity is available since the previous release.
- Restricted the Entity Editor to display of set clauses to maximum 250 for ACFLD to avoid performance issues.
Resolved Issues
- HyperView crash issue while reading SysWeld ERF result file is resolved.
Resolved Issues
- HyperGraph reader crashes when reading SysWeld ERF result file.
