Altair HyperMesh 2021.2 Release Notes
Aeroelasticity
Enhancements
- Model Check for CAERO1 flow direction is matching LCS in AEROS or global Xe.
- Context support for aero loading.
- Context support to calculate bias table for panel meshing.
- Enhance Panel mesh GUI with domain editing.
- Provide facility to create/edit TABDMP1 in aeroelasticity browser.
- SDAMP should be added in Solution control for Flutter.
- Update ANALYSIS types as per changes in OS solver.
Resolved Issues
- Error message in status bar upon creating Aero and Aeros cards from solver browser.
- Issues with accessing References from Aeroelasticity browser in a clean settings.
- Delete Advanced option not working on many entities in Aeroelasticity browser.
- Definition of PARAM card with VREF comes in model browser under Ungrouped.
- NF entry of FLFACT is converted to Real during export.
- Rename FLUTTER to FMETHOD is flutter case control and export.
- Remove unsupported options from Flutter methods Defect.
- Unable to export model with MONPNT1 with set assigned.
- "Sensor definition" details needs to remove for MONPNT1,MONPNT2,MONPNT3.
- Aero global output cards are not importing back after export.
- Aero global output cards are missing from TOC solver browser.
- CAERO1:Panel mesh failed with no spatial numbering.
- For StaticAeroelasticResponse, ANALYSIS=SAERO.
- Define Aeropanel in local system shows coordinates in global system.
- Session crashes on creation of a panel mesh using LCS.
- Analysis type for Static Aeroelastic Response and Aerodynamic flutter should be set to SAERO & FLUTTER automatically.
API
See the 2021.2 API Programmer’s Guide for the full list of new features and enhancements.
Enhancements
- New Internal ID Management
- From this version onwards, HyperMesh synchronises the internal IDs with solver IDs whenever possible, the exception being models with duplicate solver IDs (allowed in Nastran, LS-DYNA, OptiStruct and Radioss solver interfaces).
- Assigning Parameters
- Parameters can be now assigned on entity attributes using
*setvalue
command, for example,*setvalue mats id=1 Rho={parameter parameter_name}
. Similarly, the parameter can be unassigned by providing an empty name string, for example*setvalue mats id=1 Rho={parameter "" }
. Upon unassigning the parameter, the entity attribute will automatically adopt the same value as the one assigned via the parameter.
Browsers
New Features
- Add metadata to entities
- The Add Metadata dialog facilitates adding metadata
to all the types of entities. The added metadata is saved to
*.hm file.Figure 1.
- Demo Browser
- New browser available in HyperMesh view menu. It allows you to quickly open files in the Demos/hm/ folder in the installation by double-clicking or right-clicking and selecting open.
- Entity Defaults
- Entity attribute default settings is a new mechanism that allows control of entities and the Entity Editor. It can be configured in the following ways:
Enhancements
- Element subcategories in Model Browser
- Subcategories for elements, based on solver keyword, are now shown in
the Model Browser for OptiStruct, Nastran, and Abaqus interfaces.Figure 3.
- Solver keyword list for Create context menu
- In OptiStrcut and Nastran interfaces, the solver keyword list under the
Create menu is redesigned to show the most used keywords at the top and
the rest under the More category.Figure 4.
- Attribute columns for Systems and Vectors
- Flat entity views are now supported for Systems and Vectors that facilitate adding any entity attribute in the browser column for bulk review and editing.
- Create Part and Subsystems from Model Browser
- Part and Subsystem entities can now be created from the Model browser.
- Embedded EE expand/collapse state
- The expanded/collapsed state of embedded EE for referenced entities is now retained across different selection of same entity type.
- Parts from includes/subsystems
- Double-click the Parts folder under an include or subsystem to show a filtered Part Browser with just the selected parts.
- Expand/collapsed state on filtering
- The expanded/collapsed state of a parent entity in the browser is now retained when a parent entity is a match for the filtering operation.
- Referenced entity check on Organize
- The new Organize option with referenced entity check is now supported in OptiStruct, Nastran, and Abaqus interfaces.
- Show/Hide/Delete attached options added to Preferences
- The Show/Hide/Delete attached options can now be changed from the Preferences dialog.
- Beam Section creation from Beam Section Collectors view
- Beam Sections can now be created in the select Beam Section collector from Beam Section Collectors view.
- Include file creation from Include view
- Under Includes view, Include File is set as the first option under Create menu for quick creation.
Resolved Issues
- Elements and nodes selected in graphics are now highlighted in browser.
- Nodes are now shown in correct include when components are moved across includes.
- Geometry and FE icons for Components are now shown in Model Browser.
- Local browser configuration options are now saved across sessions.
- Active browser now switches upon switching browser by clicking on browser tab.
- Add Column option is now available for Component’s Property and Material under Radioss interface.
- Export CSV from the browser with special character in the name now works.
- Component no longer moves out of assembly upon tetra meshing.
Known Issues
- Entity editor is not cleared when an entity is removed from the filtered browser list.
- Collected entities are not updated correctly upon making the respective collectors inactive.
- In the Demo Browser, you can only open files. Import is not supported.
- In the Demo Browser, only .hm files are supported.
Certification
Enhancements
- When assigning a Structural property per designpoint, a deep copy of entities referenced by the selected Structural property is performed.
- Material metadata for First_ply_Failure method are now created on all materials with card image MAT1/MAT8 when method is created. Previously, it was only created when method was assigned to designpointset.
- Session methods saved as a user library are auto-mounted as library and removed from session library (hence no more duplication).
- New icons in Method Manager to directly Add or Import method library.
Resolved Issues
- Undo/Redo of Designpoint Add/Remove is now working.
- Method output argument renaming is now maintained after registration.
- Method created from Registered Compose functions are now assigned the proper engine type.
- Compose registered functions are now listed as Resources on Linux.
- Running multiple Designpointsets is now allowed if no method was added in Run Context.
- Running multiple Designpointsets now creates a table for the first Designpointset in the list.
- Chaining method in Linux now retrieves argument from previous method table.
Composites
New Features
- Ply Types
- Ply product type support has been added for Unidirectional, Weave (homogenized and unidirectional models), Core, and Filament Wound.
- Composite Stress Toolbox
- Analysis entity stores entities (materials, plies, laminate, or zones) along with all other analysis specific settings. This allows easy setup of and access to classic laminate theory calculations including engineering constants, strength, load response, and first ply failure.
Enhancements
- General
- Kinematic draping support added for Abaqus, Ansys, LS-DYNA, and Radioss profiles.
- First ply failure methods can be created in composite browser and assigned to laminate strength and load response/first ply failure analyses.
Known Issues
- Wrinkling failure in First Ply Failure method is not net supported for Abaqus.
- Drape estimator has orientation mapping issues for certain models. Kinematic draping should be used instead.
Resolved Issues
- Composite browser context menu no longer gets stuck on certain delete operations.
- Fibersim export - the correct total list of elements is now exported if a ply has multiple sets assigned.
- Drape estimator and Laminate Tools draping have been deprecated and placed behind an environment variable. Kinematic draping should be used instead.
- Laminate spreadsheet export now writes solver ids instead of internal ids for ply shapes.
Connectors
New Features
- Auto Line
- A new tool to auto-create line connectors on 2D geometry and mesh has been added.
- Master Connector File
- The Master connector file has been renamed Main Connector File.
- Solid Seam Imprint with Heat Affected Zone (HAZ)
- Two new realisations have been added to model Seam welds with HAZ: Hexa based realisation and Penta based realisation.
- Absorb
- The absorb workflows are now exposed through ribbon tools in the new interface.
Enhancements
- Attachment Improvements
- Projection Attachments have been extended to Rigid Spider Attachments.
- Tags can be absorbed as Node Attachments.
- The Attachment links can now be replaced in the Browser.
- Attachments on solid holes have the option to realise to all the nodes in the hole in the control.
- Attachments on solid holes have the option to realise to the solid face.
- Attachments can now realise to a second washer layer.
- Attachment interface ID can be altered when the Attachment is unrealised. The ids selected are checked to ensure they're free and then reserved.
- In OptiStruct and Nastran, the Attachment name is pushed to the interface node grid comment.
- Absorbing a Rigid Spider places the Attachment at the center node location.
- Absorbing a Rigid Spider with a GRID Comment will push the name to the Attachment.
- Absorb Improvements
- Absorb mechanism has more link types: Parts and Properties.
- Absorb can now absorb spots as a connector spot line.
- Unity Improvements
- New option in the Line tool hamburger menu to merge close lines when all selected simultaneously. It will merge all of the lines that have a start/end at the same location.
- For Point and Fastener selection for nodes and points, "Box selection" has been set as the default. The option to turn snapping on is in the hamburger menu under Snaps. You can then alternate between "Box selection" and "Snapping".
- Split to Points and Add Node Location as Link were added to the Spot tool in the hamburger menu.
- Auto Pitch/Auto Point new tool to map the auto pitch tools to the new interface.
- General Improvements
- Connectors will no longer realise to a Realize component when No/Skip Post has been set to on. Components are created following a standard naming convention to ensure consistency.
- Connectors will put the Property and Material (where the material is defined on the component) in the Component realisation name when using No/Skip Post.
- hm_createmark can now be used to select Connectors by Subsystem.
- HiLock Fastener has been adjusted to allow for PCOMPG or PCOMPP as properties on the component links.
- HM Metadata is written out in the Connector XML when exporting.
- The control binary file can now be auto-loaded by defining the control file in the Connectors area of the Preferences dialog.
Resolved Issues
- Subsystem connectors no longer incorrectly absorb to the wrong include.
- A Subsystem connector can now be reclassified as a General connector. This will only happen if every link is present in the model, can be resolved, and are in the same Subsystem.
- Adding the control as a column no longer shows the connector control name rather than ID.
- When absorbing duplicate rigids at the same location, a single Attachment is created.
- The default for the Connector Subsystem creation is now set to Single rather than Paired.
- Connector Line tool documentation adjusted for clarity.
- Using attachments with incompatible control types now shows a meaningful error message.
- Connector Combine issues resolved.
- Links with ZOFFS: Bottom are processed correctly.
- When the indirect option is selected, a Property in No/Skip Post is assigned.
- Part rep saving with attachments has been fixed.
- HiLock now resets the mesh imprint methods when changing controls.
- Importing a control binary file over an existing session updates the connectors and no longer leaves them marked realized.
Design Explorer
New Features
- Measure Response
- The measure response allows you to create responses from various useful measurements of interest: distance between, position, relative displacement, relative angle, and angle between. In each case, you will select the appropriate number of nodes to capture the measurement, and the measurement will be evaluated and reported in each run of the exploration.
Design Space
New Features
- Adhesives design space workflow has been added. Adhesive tool automatically
identifies flange locations from the selected entities. It also creates a
Tie based contact between Adhesives design space (voxels) and the structural
elements nearby. It does not add any additional stiffness as it does not
create any contact between structural parts. Figure 7 used to
improve stiffness, but the adhesive length is not optimized.Figure 7. Sample Automotive Model with Structural AdhesivesFigure 8. Evolution of Structural Adhesives Before and After Optimization
- Tie connect workflow has been added that generates contacts only between the selected design space and nearby structural elements.
Fields
New Features
Supports CSV/TXT Heat Coefficent/Temperature mapping for ADVC solver profile.
Enhancements
- OptiStruct
- op2
- Nastran
- op2
- xdb
- ANSYS
- rst
- rth
- Abaqus
- odb
General
New Features
- Toolbelt
- The Toolbelt, a feature known from Altair Inspire, has been introduced to HyperWorks. You can quickly access frequently used tools by using the preset defaults or by defining a personalized Toolbelt by dragging and dropping. Modified definitions can be exported to an .xml file and shared with others.
- Selection search interface for Entity Editor
- A new typing interface with live search suggestions is now available to
select individual entities in the Entity Editor. To select by entering
names or IDs, use the button, or press . or Figure 10.
. While typing, the selection search function provides
live suggestions of names and IDs that contain the typed search terms.
If the model contains more partial matches than listed in the
suggestions list (configurable in Preferences), you can also click
Browse More, or press , to browse and select from the full partial match
list.
- Advanced Selection Operators: Add, Remove, Intersect
- Figure 11.Figure 12.
- Cascaded advanced selections
- The
button is now also available for selection methods inside the Advanced Selection dialog, allowing to perform multi-level extended selections. For example, selecting Elements, By Property, and By Include:
Figure 13. - Renumber tool
- A new Renumbering tool is now available on the Assembly ribbon. In addition to a modern UI and workflow, the new tool provides enhanced feedback and also offers the ability to renumber ordered lists of nodes and elements.
- Spatial ID Manager
- A new Spatial Renumbering tool is now available on the Assembly ribbon.
It allows you to renumber nodes/elements using the system axis:
- Pure spatial sorting with constant increment of ID.
- Following rectangular grid schema with different increment per direction (same as the legacy tool).
- Using adjacent elements: You no longer need to select the direct adjacent element to define direction (internal path search is performed).
Enhancements
- Selection
- Set Segment contents selector in Entity Editor has been migrated from
the legacy panels to a new Entity Selector that allows appending and
deselecting the segments’ base elements directly.
- Use standard selection controls to append or deselect Elements, Facets, Faces, or Edges where the Segments are defined.
- Click
to reverse or align Segment directions using the Adjust Directions dialog. The Reverse function flips all or some Segment directions simultaneously. The Align function is only available for Segments defined on shell elements.
- When selecting 3D elements, Segments will be added to their outside faces only, based on the current display state.
- While selecting Set Segment contents, you can freely switch between supported selection types (for example: Elements, Facets, Faces) and the current selections will be converted accordingly.
- Consult the product documentation for additional restrictions and considerations for this special selector.
- Preferences
- HyperWorks Preferences are available in the Preferences dialog where you can edit preferences for all loaded clients in the current session in one place.
- Nearby
- Many more entity types are now supported for finding nearby the current
selection:Figure 17.
- Model files removed from installation package
- To reduce the footprint size, the following tutorial model and demo model files are no longer included in the local installation. You can now find zipped tutorial model files and demo model files on Altair One via the Altair Community, Altair Marketplace, and Altair Connect sites. Altair recommends that you create an Altair One account and use it as your primary portal to access product documentation, a Knowledge Base, and customer support.
Resolved Issues
- Issues related to pinning HyperWorks to the taskbar or invoking HyperWorks from a pin in the taskbar in Windows have been resolved. This fix applies to all HyperWorks applications that have start menu shortcuts.
- An issue affecting the display and refresh of the GUI while using a remote display manager in next-generation applications including HW, Inspire, and SimLab, has been fixed.
- Performing quick advanced selection (Alt + Select) of Elements > By Path with the Fill Path loops option enabled is now possible. The enclosed loop area will be selected upon releasing the Alt key, without the need to press MMB (since Alt + MMB is a differently assigned shortcut key).
- Fixed an issue where currently selected Parts were not being automatically inherited when entering the Move tool or other tools supporting Part selection.
- Fixed an issue where the session crashed while hovering over the undo list in the Edit menu.
Known Issues
- If you have more than one defined keyboard language, pressing ALT + SHIFT to open the toolbelt also switches the language. The shortcuts for switching keyboards can be modified in the Windows settings for Languages.
- In HyperWorks, if you start HyperView without cleaning your settings first
and then switch to HyperMesh, the solver profile is not loaded properly,
though there is a checkmark by it in the Solver Interface menu. This results
in the loaded/available element types and full entity properties not being
visible.
Workaround: Select the solver interface from the Solver Interface menu (File → Solver Interface), even if it already appears selected, to manually load the profile.
Geometry
New Features
- Sketch
- HyperWorks 2021.2 features a new sketching interface and a number of new sketching tools. You can create sketches, add dimensions, convert driving dimensions to reference dimensions, and add constraints. Highlights include:
- Cut Hole
- New tool on the Geometry ribbon to create holes in geometry/2D mesh using predefined shapes as:
Enhancements
- Parasolid option added to detect and remove fillets
- Added auto-imprinting options for nodes and geometry creation tools
- Imprint tool now supports node imprinting on lines
- Splitting a line with multiple lines added
- Defeature holes tool shows count of number of holes detected
Resolved Issues
- Fixed issues with detection of thin solids for models with T-connected edges for midsurface extraction
- Miscellaneous issues related to ruled, split and defeature hole tools fixed
Matrix Browser
New Features
- New Access Point
- The Matrix Browser can be now accessed from the Query section of the Post ribbon. Note that Matrix is no longer accessible from the Aerospace pull-down menu – the entire Results section has been migrated to the Post ribbon.
- Results Query
- The result data coming from the Results entity in HyperMesh can now be queried via the Matrix Browser. A new item – "results" – has been added at the end of the list of available data names for elements and nodes.
- New Settings Options
- Two new options have been added to the Settings:
Enhancements
- Solver IDs vs Internal IDs
- The Matrix Browser lists the internal IDs in the entity query column. Historically, this has posed challenges when exporting the data and matching it with solver data because the internal and solver ID were often different. Thanks to the new internal ID management, HyperMesh now synchronizes the internal IDs with solver IDs whenever possible, the exception being models with duplicate solver IDs (allowed in Nastran, LS-DYNA, OptiStruct, and Radioss solver interfaces). Also, the solver ID is now available across all the entities as a core data name, and it can be directly queried in the Matrix Browser.
- Removed Deprecated Data Source
- The MatDB data source has been removed from the selection list.
Known Issues
- The results query is not yet supported by the macro recording. This requirement will be addressed in the future release.
Meshing
2D Meshing
New Features
- Associativity to geometry
- Always maintain original node associativity to geometry like vertices/edges/surfaces/solids. Most geometry, meshing, and mesh editing tools, with a few exceptions, are instrumented to use new associativity. Mesh will no longer lose geometry associativity on editing.
- Edit Elements
- Added Origin tool to review associated nodes moved away from the geometry and move them back to their initial positions.
- Doubler
- Doubler workflow has been added under 2D → Mesh to create a part that provides localized performance benefits for multiple design attributes such as NVH, Safety, and so on. The workflow creates the physical part at the desired location, applies thickness and material properties, and also connects the part to the surrounding structure.
- Edge layer mesh controls
- Edge layer mesh controls added to generate 2D BL layers.
Enhancements
- General 2D mesh and Panel Mesh
- Added “Element organization” and “Treatment to connected mesh” options at local context level.
- Enhanced Face Edit tool workflow and added new mapping method for Map as Triangle (Tria centre and Tria corner).
- Extended support for number of layers upon Redo connectivity.
- Edit Elements
- Replicate tool enhanced to Auto detect FE stitch shared edges with 2d-3d elements.
- Edit Density tool supports element re-mesh with specified number of layers.
- Box trim UI and workflow enhanced.
- Section Property (in Mesh 1D Group)
- Performance improvements when intersecting 3D elements
- New feature to consolidate the beamsections resulting from multiple cuts using a tolerance on calculated moments of inertia. This reduces a lot the number of section created.
- New option to translate beams to the actual shear center location instead of applying offset
- 1D Beam Review
- New flag to review offset values as tooltip while hovering mouse on element
- New item in legend to display orientation vector along with x,y,z elemental system
- Bulkhead
- Within the bulkhead workflow, it is now possible to apply the material to the newly created part.
Resolved Issues
- Fixed miscellaneous issues in the Refine tool and addressed inconsistencies.
- Midmesh Align distorting mesh resolved.
- Fixed topology revision issues related to remeshing of geometry after unstitching of T-connections
Solid Meshing
New Features
- Added “Thin Solid” tool in Mesh ribbon to generate Hexa-Penta mesh on thin solids like sheet metal solids and electronic components having relatively smaller thickness.
Resolved Issues
- Resolved “Growth Rate” issue related to Tetra mesh.
- Solid Map tool now allows selection of partial mapped solids upon clicking on “Find” option.
- TetraMesh panel bug (application hang) pertaining to the Abaqus profile fixed.
Model Build
New Features
- PDM Live connections
- HyperMesh can interact directly with PDM systems via the Part Browser. It can download/upload data to PDM systems from within Part Browser on Demand. This makes the HyperMesh-PDM integration more robust and very intuitive, helping the CAE world to work seamlessly with the PDM world.
Enhancements
- Identifying and linking symmetric parts as instances is now supported.
- Support for parts and instances is added to the Mirror tool. Mirroring a part with "Keep original" will create a new mirrored instance of the selected parts.
- When loading part representations, there is now a progress bar so you know how far through the load process you are.
Resolves Issues
- When a component is moved from one part to another, it is no longer automatically transformed by the new part's position; it is instead left in the same position in space.
- After going to a New Model in a HyperWorks session, the Model subsystem is no longer exposed.
- The subsystem icon will now update when parts or components are shown, hidden, or isolated so you can check which subsystems are displayed.
- Since connectors are listed directly in the Subsystem Browser, the Connector section from the Subsystem Entity Editor has been removed.
- Creation of multiple subsystems from Includes now creates subsystems in the same order as the Includes.
- The Library and Export Deck options were available in the Subsystem Browser only in HyperWorks. They are now available in HyperMesh as well
Model Verification
New Features
- Quick Comparison works for user-selected Parts directly from HyperWorks
graphics.Figure 20.
- Export unmatched surfaces to 3D data for CAD vs CAD Comparison with DLT string appended on the exported CAD file.
- User-defined metadata values can be selected and appended to the existing Excel report through Tool/Edit Excel utility.
- Auto-migration of configuration file supported for both major and minor version as well.
Enhancements
- CAD vs FE comparison, matched area is shown in transparent mode in the
PowerPoint thumbnail images. Unmatched area is shown in shaded mode.Figure 21.
- BOM Comparison displays 31% Match if Part Revision is mismatching but Parts Name/Number/PID is matching.
- Merge Comparison Excel reports to single/few based on user input. For every result ranges, MergeExcel.xlsm is created.
- Skip calculating Oriented BBox from Cad or FE if component has zero nodes/surfaces.
- New Part pair Revision filters are added (Same-Pid-Only+Revision....).
- BBOX creation is improved to exclude scattered parts while calculating and distributing parts for the parallel processing.
- Connection Holes-Mismatch and Holes-Pair-Mismatch checks are parallelized for the reports.
- File size check is added before attaching the common representation to a Part (applicable to offset function).
- Part Match function the #solids count depends on Parameter.
- Connection Check and Report, Parallel session starts after 10min of delay to accommodate load balance.
- Delete Connection/Unwanted filter groups from configuration file at
once.Figure 22.
Relocation of Parameters
- All color related parameters for the comparison function is moved under compareunified/report/color.
- BOM Comparison related parameters are moved compareunified/Bom comparison
- String Range parameter for controllling Part Name, Number, Assembly names are moved under general/tool.
Resolved Issues
- After an MVD run, configuration from mvd temp folder was active.
- Connection Check, hm_getmark errors displayed on huge models.
- Part Match, renaming Part Set name considers PartName in addition to PartNumber.
- Mixed Import, will work directly from Intersection GUI.
- BOM Comparison, Part color is being displayed for unmatched range when 3 levels threshold value is chosen for CAD-CAD compare.
- Representation file type gets changed from FEM to CAD file when cadtofeapproach is executed using browser selection method for the 2nd time.
- Module Pair Ignorable filter must accept attribute PartName in addition to PartNumber.
- Configuration, Search option not working if the Tree is in a collapsed state.
Morphing
New Features
- Morph Normal to Mesh
- In the Free and Proximity morphing tools, it is now possible to toggle
the Move tool mode between translating & rotating (default), or
offsetting normal to mesh. Click
in the Move tool microdialog to replace the standard Move tool with a single normal offset arrow. While in this mode, drag or click on the arrow to type a normal offset value to move the nodes. Optionally, use the microdialog buttons to review and edit the normals calculation options and area. This mode is not available for nodes connected to 3D elements.
Figure 23. - Morph Remesh and Rebuild Options
- New options have been added to the Free, Proximity, and Volume morphing
tools to monitor specified element quality criteria during morphing and
automatically offer to remesh the affected elements using HyperMesh's
rebuild or remesh technologies. The morph remesh microdialog appears
when the specified remesh conditions are met, and allows reviewing and
editing of the remesh parameters and area of effect. It is also possible
to selectively skip any triggered remesh condition. When remeshing a
morphed mesh using these tools, the morphing vectors are also
automatically mapped to the new mesh, so it is still possible to save a
morph shape from the morphed and remeshed area.Figure 24.
Enhancements
- Undo All Morphs
- Undo Shapes as Morph Input
- It is now possible to select existing morph Shapes as input to create
new morphs using the Free and Proximity morphing tools. When selecting a
Shape, the Move tool is replaced by a shape magnitude arrow that can be
used to move the nodes freely along their Shape. The magnitude is in the
form of a multiplying factor with respect to the selected shape.Figure 25.
- Other enhancements
- Changed the default values for the 1D/connector automatic
clustering parameters in the global section of the morph
options. The new defaults represent less constrained morphing
conditions that can speed up many morphing scenarios
significantly. Models already created and saved using the
previous default values will not be affected, as these settings
are saved with the model. The new default values for these
options are:
- Connector/cluster/eq morphing = use doms/mvols
- Stretch mesh around clusters = off
- Morph volumes are now temporarily hidden from view while animating morph shapes.
options are:
Resolved Issues
- Fixed a performance issue in Proximity morphing where using the "Morph only connected nodes" option could cause additional delays in some models.
- Fixed an issue introduced in version 2021.1 where the automatic Morph Area detection in the Free morphing tool was sometimes propagating beyond the expected connected faces.
- Fixed an issue where microdialogs could post in an overlapped manner in some morphing tools.
Post
Highlights
A brand new set of tools and workflows has been released in HyperWorks (HM) on the Post ribbon to allow direct integration of native results readers into HyperMesh and perform results visualization on the model via:
- Contour plot
- Vector plot
- Tensor plot
- Deformation plot
The new workflows are available for the following solver profiles:
- OptiStruct
- Nastran
- Abaqus (Plot Workflow as Beta)
- ANSYS (Plot Workflow as Beta)
For all other solver profiles, the Post ribbon hosts a configuration which points to older panels for Contour, Vector, Deformed, and Transient workflows, which rely on *.res file availability.
Plotting
New Features
- Importing Results
- Results can be imported directly into HyperMesh using .
- Results Browser
- After importing the results, you are brought directly to the Post ribbon
with the Results Browser open. The browser can always be re-opened by
clicking the Results tool on the Post ribbon.
- Plotting Tools
- Each plot workflow relies on a plot control entity and can be accessed
either via the Plot or Create options.Figure 26.
Known Issues
- For ANSYS (Beta), post-processing results display on 2nd order elements has an issue when corner data are set to ON.
FBD
Enhancements
Resolved Issues
- Correction of graphic scale factor
- Resolution of results transformation with respect to cylindrical system
- Resolution on Trace Plot results display depending on direction of node path
- Resolution on load creation
Query
Enhancements
- Results Query
- MinMax/Ranking/Envelop
Safety Tools
New Features
- Seat Foam Deformer
- This new feature allows you to perform the seat foam deformation process directly in HyperMesh. Compared to the existing seat deformer using the pre-simulation approach, the seat foam deformer enables you to quickly get high quality results of the new seat foam shape, removing intersections with the dummy.
- Dummy pre-simulation
- A new feature in the dummy pre-simulation tool now allows you to directly select the initial dummy file, which is then automatically used for the simulation process. HyperWorks only exports an include file containing the load case information and a master file referring to the dummy and load case includes. This leads to an improvement of the performances of the tool, reducing the time for the export of the simulation deck.
- Combined seat and dummy pre-simulation
- This new feature, accessible from the Dummy pre-simulation GUI, enables you to set a pre-simulation run to perform the seat deformation and the dummy deformation in a single stage. This improves the occupant safety model set-up process by reducing the simulation time requested for the seat and dummy pre-simulation.
Enhancements
- Mechanism tool
- The joints attributes are now fully editable after the joint creation process, allowing an easy update of the joints. Delete and re-create the joint is no longer requested.
- Seatbelt system performances
- The performances of the seatbelt system tool are drastically improved, especially when modifications operations on the belt are applied. For example: interactive modification, belt update on dummy & seat motion, mesh size, or mesh type change...
- Pedestrian tool
- The marking of impact locations on outer surfaces is improved by considering openings, for example on the hood.
Resolved Issues
- Reading of the Radioss native H3D file to update airbag, dummy, or seat with simulation results, is now working.
Solver Attribute Mapping
Solver Conversion
Enhancements
- Abaqus to OptiStruct conversions
- RIGID BODY converted to RBODY with GPAD=NONE
- SHELL SECTION(SC8R) converted to PCOMPLS
- CONNECTOR JOIN converted to RPIN
- CONNECTOR DAMPING converted to PJOINTG, DAMP
- HYPERELASTIC+*VISCOELASTIC converted to MATHE+MATVE
- JOIN, ROTATION converted to RPINROTA
- PLANE, ALIGN converted to INPLORIE
- CONTACT CLEARENCE converted to CONTACT PAIR+MODCHG
- CHANGE FRICTION converted to PCONT+TABLEG
- Ansys to OptiStruct conversions
- MASS21(Keyopt(3) = 2 ) converted to CONM2
- MPTEMP, MPDATA,NU converted to MATT1(NU)
- CONTAC173/CONTACT174/CONTACT175/CONTACT177 are converted to RBE2 when KEYOPT (2) = 2 (MPC) and slave is a 1-node PILOT NODE set to KEYOPT(4) = 2
- CONTAC173/CONTACT174/CONTACT175/CONTACT177 are converted to RBE3 when KEYOPT (2) = 2 (MPC) and slave is a 1-node PILOT NODE set to KEYOPT(4) = 1
- MPC184 converted to RBEAM Joint if KEYOPT(1) = 1 and RDOF = blank in SECJOINT
- MPC184 converted to BALL Joint if KEYOPT(1) = 16 and RDOF = 1,2 3 in SECJOINT
- MPC184 converted CARTESIAN+ CARDAN Joint if KEYOPT(1) = 16 and RDOF = blank in SECJOINT
- COMBIN39p converted to PELAS/PBUSH
- JOIN converted to RPIN
- SECTYPE,SHELL converted to PCOMP
- SECTYPE,SHELL(one layered solid) converted to PCOMPLS
- SECTYPE,SHELL(SOLSH190) converted to PCOMPLS
- LINK180 converted to RLINK
- BEAM189 converted to CBEAM
- ADVC to OptiStruct conversions
- PretensionSectionElement converted to PTFORCE, PRETENS
- PrestensionSectionSurfaceList converted to PTFORCE,PRETENS
- InitialTemperature converted to SPC
- Radioss to OptiStruct conversions
- /PROP/SPR_BEAM converted to PBUSH
- /ADMAS converted to CONM2
- /GRAV converted to ACCEL2
- Abaqus to Radioss conversions
- C3D10 converted to TETRA10
- C3D10I converted to TETRA10
- BEAM SECTION converted to /PROP/INT_BEAM
- SPRING(Nonlinear) converted to P4_SPRING
- DLOAD converted to /PLOAD
- DSLOAD converted to /PLOAD
- INTIAL VELOCITY TYPE=ROTATION converted to /INVEL/AXIS
- CONTACT INCLUSIONS,ALL ELEMENT converted to TYPE24
- Dyna to Pamcrash conversions
- CONTACT_AUTOMATIC_Single_Surface(with mortor) converted to CNTAC36
- CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_ID(with mortor) converted to CNTAC33
- CONTACT TIED EDGE SHELL TO SURFACE converted to TIED
CAD and Solver Interfaces
Abaqus Interface
New Features
- Analytical Rigids
- New graphics support to visualize analytical rigid surfaces along with a toolbox to create those surfaces.
- Duplicate Names
- Duplicate names are now allowed in set entity based on name pool shared between node set, element sets, and set segments.
- Contact Surface Mapping
- New preference option that allows contact surface to map between shell and solid once the base element attached to the contact surface is deleted.
Enhancements
- Auto-Surface Generation for Bolt Pretension
- Pretension manager tool is enhanced with the ability to create bolt pretension surface and node using a direction and a base node selection option.
- Rigid Body Migration
- Rigid body definition is migrated from property entity to an RBODY entity. Additional enhancements are made to reviewing the rigid body.
- New Keywords
- *STEADY STATE TRANSPORT
- Enhanced Keywords
- *DLOAD with viscous body force (VBF) label
- Contact Browser
- Added clearance column to the middle window of the Contact Browser.
Resolved Issues
- BOUNDARY with FIXED was not exporting properly and the issue is fixed.
- An issue with property and material not retaining color from HM comments is addressed.
- Improper import of DLOAD with TRVEC is fixed.
- Review of surface in pretension manager was causing application error.
- CONTACT STABILIZATION keyword was causing segmentation error and the issue is addressed.
- Apply quote rules for *DISTRIBUTION had issues with export.
- Application error when using Abaqus parts and instances based module ID manager is resolved.
- Swapping contact pair to general contact did not convert surface interaction property.
- When Abaqus Aerospace profile is invoked, it was causing application error.
- Cleaned-up issues with quotes on names for *PSD and *CORRELATION keywords.
- Entity Editor for Tie/Contact pair was not showing all card images and the issue is resolved.
ADVC Interface
New Features
- New Cards
- Support of $SubordinateNodeClearance
- Support of deprecated $SlaveNodeClearance
- Support of $FilmCoefficientInTable
- Support of $Element HeatConvection8
Enhancements
- Auto-contact function added. It can be accessed from the ribbon and the Contact Browser context menu.
- Rigid link tool is added so that you can create Rigids via a HyperWorks workflow.
- Changed Master and Slave labels to Main and Secondary for the Contacts.
Resolved Issues
- Fixed an issue in Contact: adjust/gap correction parameter allows both value/yes options
- Allow reading for empty sets or segment sets in ADVC
- Allow export for contactgroups even with no groups assigned
ANSYS Interface
Enhancements
- Contact group header in the Contact Browser changed to Main and Secondary.
- Auto Contact updated with use shell thickness feature with options.
- SHELL181p, SHELL281p real property are removed and are realized with SECTYPE SHELL (with thickness mapped).
- SOLID95p real property is removed.
- Multiple data lines of super element (SE) supported.
- IRLF supported at subcase level.
- TBFIELD, TEMPS is supported.
- CONTACT174 is updated to version18 and above.
- SECTYPE, SECID, CONTACT, BOLT is supported.
EXODUS Interface
Enhancements
- Rigid Spider (RBAR) and RBE3 can now be created and edited through dedicated tools.
- RBE3 is created with independent block (component) and weight factor can be provided in all 6 DOF.
- Spotweld tool is available in panels to create attachments and connectors.
Resolved Issues
- Duplicate ID warning upon import
- Missing WTx input in RBE3 element
- Set Segment names during import are now with ID
- The Beam Section icon in the Mesh and Marine ribbons was missing
CAD Interface
Enhancements
- Updated Version Support
- NX 1953 (CT reader)
- NX 1957 (CT reader)
- Creo 7.0
- Catia V5-6R2021
- Solidworks 2021
- Inspire 2021.2
Resolved Issues
- Added an option to remove degenerated surfaces on import.
- Assembly hierarchy difference issue and import failure with monolithic Step file format fixed.
- Fixed default import of hidden parts when hidden parts option turned off for Creo assembly files.
LS-DYNA Interface
New Features
- Support of LS-Dyna solver version R11.2
- The LS-DYNA solver profile R11.2 is now available with the relevant keyword updates related to this solver version.
- New State Equation entity
- The State Equations entity collects the LS-DYNA EOS keywords, which were previously defined into the Property entity.
- New Model Clean-Up tool
- The new Clean tool on the Validate ribbon is an efficient way to delete automatically all Empty or Unused or Undefined entities from the model, which may be created during model modification operations.
- Model units conversion
- The new Unit conversion tool on the Model ribbon provides an efficient way to convert a model from its original unit system to a new unit system. The covered unit systems are: (N,m,s,kg); (N,mm,s,T); (kN,mm,ms,kg); (N,mm,ms,g)
Enhancements
- New Keywords
- *CONTROL_MPP_DECOMPOSITION_REDECOMPOSITION, *DATABASE_RCFORC_MOMENT, *DEFINE_CURVE_DUPLICATE, *DEFINE_ELEMENT_EROSION, *ELEMENT_SOLID_H8TOH27, *ELEMENT_SOLID_H8TOH64, *INCLUDE_PATH_RELATIVE, *INITIAL_HISTORY_NODE_(OPTION)
- Updated Keywords
- *AIRBAG_PARTICLE, *DATABASE_EXTENT_BINARY, *DEFINE_TRANSFORMATION, *MAT_GLASS, *MAT_PIECEWISE_LINEAR_PLASTICITY, *MAT_SPOTWELD, *MAT_SPOTWELD_DA, *MAT_USER_DEFINED_MATERIAL_MODELS (MatFEM material law48), *SENSOR_DEFINE_FORCE
- Comment anchoring to referenced entities
- The Comment entity is enhanced to support referenced entities selection. This provides a convenient way to defined comment lines to a dedicated entity or group of entities. When an entity is referenced to a Comment entity, the *COMMENT is automatically written just before the referenced entity or group of entities.
- Intersections and Penetrations Check tool
- The algorithm is improved with following enhancements:
- Export of LS-DYNA I10 Format
- A new export option is added to choose the type of i10 solver deck to write out. The exported deck can be written with the option i10=Y in *KEYWORD, or, with % sign at the end of each solver keywords.
Resolved Issues
- ID offsets defined in multiple nested *INCLUDE_TRANSFORMs were not applied properly for some entities.
- Modification in *CONTACT_TIED_NODES_TO_SURFACE Entity Editor to avoid OFFSET and CONSTRAINED_OFFSET options to be activated together, which was leading to a wrong keyword definition.
- *DEFINE_ELEMENT_DEATH keywords will not be found as unused when checking for unused properties.
- Correction to find correctly unused *MAT_ADD keywords when checking for unused properties.
- Unused and Empty function is added for Sensor entity.
- Empty function is added on Blocks entity to identify empty *DEFINED_BOX keywords.
- Corrections in the detection of Empty contacts.
- Empty function is added on Loads entity.
- Dummy or Mechanism Positions are now not listed when checking for unused entities.
- Display state for Pretensioner entity is added.
- SET_SEGMENT and CONSTRAINT_JOINT are written with keywords attributes comments “N1, N2, N3, N4” only on the first line.
- Nodes IDs with offsets applied by INCLUDE_TRANSFORM are now correctly identified in COORDINATE_SYSTEMS definition.
- CONSTRAINED_NODAL_RIGID_BODY, CONSTRAINED_NODE_SET, CONSTRAINED_GENERALIZED_WELD and CONSTRAINED_SHELL_TO_SOLID defined with SET_NODE_GENERAL_COLLECT are now correctly read.
- 3rd node of ELEMENT_BEAM is not more considered when checking untied nodes in TIED contacts.
- In Orthotropic Materials, the material angle attribute is renamed to BETA as in solver manual.
- Transformation of type POINT are now selectable in entity editor of POS6P transformation.
- Changed entity editor definition of *MAT_ADD_EROSION to allow the parametrization of attribute DMGTYP.
- An input deck having more than one *AIRBAG_SHELL_REFERENCE_GEOMETRY is now correctly imported. The behavior was broken in version 2021.1.
Nastran Interface
New Features
- Superelement boundary element reassignment
- SEELT bulk added to set entity in MSC and NX Nastran profiles.
Resolved Issues
- TYPE field missing in TABLES1 card.
- KT field in PGAP is imported as 0.0 instead of blank.
OptiStruct Interface
New Features
- Darcy flow analysis
- New bulk cards to define Nodal Pressure (SPCP) and Inlet velocity (INLTVEL)
- Supported as new load management from the Solver Browser
- String-based input
- Labels export support extended for set (Elem, Grid), set segment (SURF) entities and their corresponding references
- OptiStruct Auto contact
- CONTACT bulk card enhancement to allow OptiStruct auto contact definition
- Supported related continuation lines
- Shear and Volumetric test data for viscoelasticity
- Shear and Volumetric test data are supported for viscoelasticity (MATVE) and frequency domain viscoelasticity (MATFVE). For both entries, the MODEL field can be set to:
- Nonlinear analysis enhancements
- Pressure-overclosure relationship can be specified through TABLEG/TABLES1 and defined in PCONT.
- Threaded bolts can be defined as part of a CONTACT interface by setting the CLEARANCE field to reference a CLRNC bulk data entry.
- Max stress criteria with FT=STRS is now available for PCOMP(G) and PCOMPP.
- Hyperfoam material type is supported with TYPE=FOAM in the MATHE bulk data entry.
- Optimization enhancements
- The following responses are available for Flow-based Forced Convection Topology Optimization:
Enhancements
- General enhancements
- Default solver card list for entities from Model and Solver Browser
- HMSET comments added for ordered/non-ordered sets on export
- MOTNJG subcase selection in linear static subcase
- Ignore export solver cards for empty entities such as Set, Set segment
- Read DMIG card if header entry is defined after column entry
- RBE2 to RBE3 config change to allow DOF update appropriately
Resolved Issues
- NSM defined for solid elements are honored in mass calculation
- DVPRELi creation issue from Entity Editor
- Exporting HM comments for convection card in large field format results in HM hang
- Plane strain element export with incorrect theta values
PAM-CRASH Interface
New Features
- Exported decks formatting
- The quality of the exported solver decks is improved with the writing of all solver keywords field names.
- Include organization
- The Organize context menu option is now made available for all entities. Furthermore, the organization of entities into an include file has been improved to automatically consider all references linked to the selected entities. This feature is also available performing drag and drop of an entity into an include file.
- Drive Mapping
- On import of solver decks that contain includes, HyperWorks now allows mapping from one folder path to another to import include files where the include path written in the solver deck doesn’t match the location of the files. This includes different paths due to different operating systems. Found in Preferences → Drive Mapping, or in the Solver Deck import options, you can define the source path where the files reside, and the target path as written in the solver deck, and use this to successfully import files without the need to edit the include paths in a text editor.
- New Keywords
- MATER 240 (Material Type 240 - Muscle) and MATER 241 (Material Type 241 - Muscle-Tendon)
Enhancements
- Intersections and Penetrations Check Tool
- Updated Keywords
- PLY Type 0 (ITYP = 0) and PLY Type 1 (ITYP = 1)
Resolved Issues
- Added improvements to LOOKU keyword for ARGUMENT and FUNCTION while create, edit, and plot dynamically.
- Older options Apply Initial Metric, which are no longer valid, are removed from the list as the new Reference Geometries entity is available since the previous release.
- Restricted the Entity Editor to display of set clauses to maximum 250 for ACFLD to avoid performance issues.
Radioss Interface
New Features
- New Engine Files entity
- The Engine Files entity is introduced to support multi-stage Radioss simulations involving multiple engine files.
- Entity export deck
- This new Model Browser option, available in the context menu of all solver entities, allows you to export a selection of entities and all their references directly to a solver deck.
Enhancements
- New Keywords
- The support of the following new keywords is added:
- Updated Keywords
- The following keywords have been updated:
Resolved Issues
- Reading of STA files for fully integrated brick elements
- Application of /TRANSFORM/MATRIX is added.
- INIVEL keyword is no longer created with default Vz value set to 1.
- /MAT/B-K-EPS is now exported correctly.
- /MAT/LAW51 with Iform=2 is now exported correctly.
- /FUNCT_SMOOTH is now selectable into Load entities.
- Correct handling of encrypted models when multiple include files are defined with the same encryption key. This is a use case which applies to some Radioss dummy models.
