HyperWorks Report 2021.2 Release Notes
New Features and Enhancements
This release provides more automated features for making report generation faster.
- Image Object Enhancements - Support for Multiple Image Output Formats
- Report images can be exported in additional formats such as AVI, JPEG, and TIFF. PNG, GIF, and H3D continue to be supported.
- Image Object Enhancements - Support for Hotspot Best Views
- Report image best views now supports additional best view modes consistent with the Hotspot finder tool in HyperView. In addition to the best view modes, image creation also supports standard views such as isometric, front, top, side views, and so on. Some options related to view creation are now obsolete and have been removed from the user interface. With this, the note formatting is also moved to the image definition rather than carrying a HyperView note as reference.
- Automation Using HyperWorks Command Language
- Coverage for record and playback for the HyperWorks Command language
(HWC), which records and plays back workflows in HyperGraph, has been
expanded to include basic report functionality. This includes:
- Create OneClick session reports.
- Create, export, and synchronize reports.
- Add, delete, and move report entities in the report structure.
Resolved Issues
- The concept of Master document has been relabeled as Layout template, to completely remove using the words master and slave across the product.
- While adding an external Word document, an option to select page range is available now.
- Loop results module allows element sets selection.
- Session Report creates images of the HyperWorks desktop resolution by default.
- Loop component/set selection does not reset when you open the selection widget.
