Time Histories
Block Format Keyword Describes the time history output request.
In order to get time history data in T-file /TFILE or /@TFILE with (timefrequency) must be defined in Radioss Engine.
The table below lists the available keywords and variables.
TH Output Keywords & Variables
| Keyword | Object saved | Variables |
| Global variables | IE, KE, TE, TTE, DTE, RKE, CE, HE, EFW, XMOM, YMOM, ZMOM, MASS, DT, SIE, TER, DTE_REL, VX, VY, VZ, CE_ELAST, CE_FRIC, CE_DAMP | |
| /TH/ACCEL | Accelerometer | AX, AY, AZ, WX, WY, WZ |
| /TH/BEAM | Beams | OFF, F1, F2, F3, M1, M2, M3, IE |
| /TH/BRIC | Solids | OFF, SX, SY, SZ,
SXY, SYZ, SXZ, LSX, LSY, LSZ, LSXY, LSYZ, LSXZ, IE, DENS, BULK,
VOL, PLAS, TEMP, PLSR, DAM1, DAM2, DAM3, DAM4, DAM5, DAMA, SA1,
SA2, SA3, CR, CAP, K0, RK, TD, EFIB, ISTA, VPLA, BFRAC, WPLA,
SFIB, EPSXX, EPSYY, EPSZZ, EPSXY, EPSXZ,
EPSYZ SXi, SYi, SZi, SXYi, SYZi, SXZi (i=1,8) LSXi, LSYi, LSZi, LSXYi, LSYZi, LSXZi (i=1,8), USRi (i=1,60) SXijk, SYijk, SZijk, SXYijk, SYZijk, SXZijk, EPijk (i=1,3; j=1,9; k=1,3) SXiUk, SYiUk, SZiUk, SXYiUk, SXZiUk, SYZiUk, EPiUk (i=1,3; k=1,3) SXiDk, SYiDk, SZiDk, SXYiDk, SXZiDk, SYZiDk, EPiDk (i=1,3; k=1,3) USR1_ijk, USR2_ijk, USR3_ijk, USR4_ijk, USR5_ijk, USR6_ijk, USR7_ijk, USR8_ijk, USR9_ijk (i=1,3; j=1,9; k=1,3) E11_ik_j, E12_ik_j, E13_ik_j, E22_ik_j, E23_ik_j, E33_ik_j (i=1,3; k=1,3; j=1,200) S11_ik_j, S12_ik_j, S13_ik_j, S22_ik_j, S23_ik_j, S33_ik_j (i=1,3; k=1,3; j=1,200) |
| /TH/CYL_JO | Cylindrical joints | FX, FY, FZ, MX, MY, MZ, F, M |
| /TH/FRAME | Frame | OX, OY, OZ, R11,
R12, R13, R21, R22, R23, R31, R32, R33 VX, VY, VZ, VRX, VRY, VRZ, AX, AY, AZ, ARX, ARY, ARZ |
| /TH/FXBODY | Flexible body | IE, KE, EFW, DE |
| /TH/GAUGE | Gauges | P, IE, DENS |
| /TH/INTER | Interface | FNX, FNY, FNZ,
FTX, FTY, FTZ, SFW (only interface types 14 and
15) Following variables are only for interface types 7, 10 and their Sub interfaces (/INTER/SUB): |FNX|, |FNY|, |FNZ|, ||FN||, |FX|, |FY|, |FZ|, ||F||, MX, MY, MZ |
| /TH/MODE | Flexible body local modes | D, V, A |
| /TH/MONVOL | Monitored
volume Airbag |
MASS, VOL, P, A,
T, AO, UO, AC, UC, CP, CV, GAMA AO1, BO1, UO1, MO1, HO1 AO2, BO2, UO2, MO2, HO2 AO3, BO3, UO3, MO3, HO3 AO4, BO4, UO4, MO4, HO4 AO5, BO5, UO5, MO5, HO5 AO6, BO6, UO6, MO6, HO6 AO7, BO7, UO7, MO7, HO7 AO8, BO8, UO8, MO8, HO8 AO9, BO9, UO9, MO9, HO9 AO10, BO10, UO10, MO10, HO10 |
| /TH/NODE | Nodes | DX, DY, DZ, VX,
VY, VZ, AX, AY, AZ VRX, VRY, VRZ, ARX, ARY, ARZ, X, Y, Z, TEMP REACX, REACY, REACZ, REACXX, REACYY, REACZZ |
| /TH/NSTRAND | Multi-strand | OFF, FX, LX, IE |
| /TH/PART | Parts | IE, KE, XMOM,
YMOM, ZMOM, MASS, HE TURBKE, XCG, YCG, ZCG, XXMOM, YYMOM, ZZMOM IXX, IYY, IZZ, IXY, IYZ, IZX, RIE, KERB, RKERB, RKE |
| /TH/QUAD | 2D quads | OFF, SX, SY, SZ,
SXY, SYZ, SXZ, IE, DENS, BULK, VOL, PLAS, TEMP, PLSR, DAM1,
DAM2, DAM3, DAM4, DAM5, DAMA, SA1, SA2, SA3, CR, CAP, K0, RK,
SFIB LSX, LSY, LSZ, LSXY, LSXZ, LSYZ |
| /TH/RBODY | Rigid body | FX, FY, FZ, MX, MY, MZ, RX, RY, RZ, FXI, FYI, FZI, MXI, MYI, MZI |
| /TH/RWALL | Rigid wall | FNX, FNY, FNZ, FTX, FTY, FTZ |
| /TH/SECTIO | Section | FNX, FNY, FNZ, FTX, FTY, FTZ, M1, M2, M3, WORK, WORKR, FX_error, MX_error, MX, MY, MZ, F1, F2, F3, CX, CY, CZ |
| /TH/SH3N | 3 node shells | F1, F2, F12, Q1,
Q2, M1, M2, M12, IEM, IEB, OFF, THIC, EMIN, EMAX, EPSD, E1, E2,
E12, SH1, SH2, K1, K2, K12, USRi
(i=1,60) USRII_JJ (II=1,60; JJ=1,99), USRII_JKK (II=1,60; J=1,4; KK=1,99) SX_JJ, SY_JJ, SXY_JJ, SYZ_JJ, SZX_JJ (JJ=1,99) |
| /TH/SHEL | 4 node shells | F1, F2, F12, Q1,
| /TH/SPH_FLOW | SPH inlet/outlet conditions | FLOW |
| /TH/SPRING | Springs | OFF, FX, FY, FZ, MX, MY, MZ, LX, LY, LZ, RX, RY, RZ, IE, F1, F2 |
| /TH/SUBS | Subsets | IE, KE, XMOM,
| /TH/TRUSS | Trusses | OFF, F, IE, A, L, PLAS |
Output for Global Variables
- IE: Global internal energy
- KE: Global kinetic energy
- TE: Total energy:
- TER: Rotational total energy:
- TTE: Translational total energy:
- DTE: Delta total energy:
- RKE: Global rotational kinetic energy
- CE: Global contact energy = CE_ELAST + CE_FRIC + CE_DAMP
- CE_ELAST: Elastic contact energy which is the recoverable energy stored in the contact penalty springs.
- CE_FRIC: Frictional contact energy.
- CE_DAMP: Damping contact energy. Only calculated for Interfaces TYPE2, 10, 18, 21, 23, and 25
- HE: Global hourglass energy 5
- EFW: Global external work
- XMOM: Global momentum in X direction in global reference frame
- YMOM: Global momentum in Y direction in global reference frame
- ZMOM: Global momentum in Z direction in global reference frame
- MASS: Global mass of the structure, including lumped mass and mass added due to mass scaling from using /DT/NODA/CST
- DT: Time step
- SIE: Global spring internal energy
- VX: X velocity
- VY: Y velocity
- VZ: Z velocity
- Global variables are always written and do not need to be requested.
- Variable names must be left justified.
- In 2D axisymmetrical computation, energies are given per radian.
- Global internal energy includes all material internal energy and global spring internal energy, but not spring rotational internal energy.
- Global hourglass energy output only includes perturbation hourglass energy for shell elements, Ishell = 1 – 4, and Ish3n = 1, 2 and solid elements Isolid = 1, 2. Numerical damping from Ishell = 12, 24 and Ish3n = 30, 31, is not included in global hourglass energy but can be output /TH/PART, hourglass energy output.
- Additional time history files (Runname_run#_i.thy) with different frequencies and variables can be generated through the option /iTH (where i = A to I). These options use the same keyword format and variables as option /TH, except for the addition of the prefix (/ATH, /BTH ...). The frequency at which data is written to these additional files is defined in the Radioss Engine option /ATFILE.
