/TH/NSTRAND
Block Format Keyword Describes the time history for multi-strand element.
/TH/NSTRAND/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
xelem_ID | |||||||||
xelem_nb | xelem_usr | xelem_name |
thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
thgroup_name | TH
group name (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
xelem_ID | Multi-strand element
identifier (Integer) |
xelem_nb | Strand order number for
multi-strand element (Integer) |
xelem_usr | Strand identifier given
by you 4 (Integer) |
xelem_name | Name of the
multi-strand element 4 (Character, maximum 80 characters) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
NSTRAND | Multi-strand | OFF, FX, LX, IE |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
NSTRAND | DEF | OFF, FX, LX, IE |
Output for NSTRAND
- OFF: deactivation 5
- FX and LX are given in the local frame.
- IE: internal energy
- Available names are listed in the
two tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- Only one nstrand element is allowed for the group.
- Within a group, two xelem_usr must not be equal.
- Both xelem_usr and xelem_name appear in the Time History.
- OFF:
- 0.0 deleted element
- 1.0 active element
- 2.0 (shells / solids): active element using small strain
- Negative value -1/-2 when the element is on stand by due to rigid body
Some intermediate values can be found during few cycles before element deletion (progressive reduction of off during a few cycles applies as a multiplicative factor to the stress, so that the stress is progressively vanished and element is deleted after ~ 10 cycles). This process applies to some element types, but not all.
