/TH/FXBODY
Block Format Keyword Outputs the time history for flexible bodies.
/TH/FXBODY/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
fxbd_ID1 | fxbd_ID2 | fxbd_ID3 | fxbd_ID4 | fxbd_ID5 | fxbd_ID6 | fxbd_ID7 | fxbd_ID8 | fxbd_ID9 | fxbd_ID10 |
fxbd_IDn |
thgroup_ID | TH
group identifier. (Integer, maximum 10 digits) |
thgroup_name | TH
group name. (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for
TH (see table below). (Character, maximum 8 characters) |
fxbd_ID | Identifier of the flexible
body to which the mode belongs. (Integer) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
FXBODY | Flexible body | IE, KE, EFW, DE |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
FXBODY | DEF | IE, KE, EFW |
Output for Flexible Body
- IE
- Internal energy
- KE
- Kinetic energy
- EFW
- Work of applied forces
- DE
- Damping energy
- Available names are listed in the
two tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
