/MAT/LAW42 (OGDEN)
Block Format Keyword This keyword defines a hyperelastic, viscous, and incompressible material specified using the Ogden, Mooney-Rivlin material models.
This law is generally used to model incompressible rubbers, polymers, foams, and elastomers. This material can be used with shell and solid elements.
/MAT/LAW42/mat_ID/unit_ID or /MAT/OGDEN/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
fct_IDblk | Fscaleblk | M | Iform | ||||||
Blank Format | |||||||||
Blank Format |
G1 | G2 | G3 | G4 | G5 | |||||
. . . M values of G (five per line) | |||||||||
. . . M values of (five per line) |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density (Real) |
Poisson's ratio. 3 Default = 0.495 (Real) |
Cut-off stress in tension. Default = 1030 (Real) |
fct_IDblk | Function identifier which scales the bulk coefficient as a function of the relative
volume. 6 (Integer) |
Fscaleblk | Bulk
function scale factor. Default = 1.0 (Real) |
M | Number of viscous terms in the Prony series (order of the Maxwell
model). (Integer) |
Iform | Incompressibility for shell elements
formulation flag. This flag is not effective for solid elements.
First parameter of the shear hyperelastic modulus. (Real) |
Second parameter of the shear hyperelastic modulus. (Real) |
Third parameter of the shear hyperelastic modulus. (Real) |
Fourth parameter of the shear hyperelastic modulus. (Real) |
Fifth parameter of the shear hyperelastic modulus. (Real) |
First material exponent. (Real) |
Second material exponent. (Real) |
Third material exponent. (Real) |
Fourth material exponent. (Real) |
Fifth material exponent. (Real) |
Gi | ith multiplier of the Prony
viscous term. 7 (Real) |
ith time relaxation of the Prony
viscous term. (Real) |
Example (Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
#- 2. MATERIALS:
/MAT/OGDEN/1/1
rubber
# RHO_I
1E-6
# Nu sigma_cut funIDbulk Fscale_bulk M Iform
.495 0 0 0 0 0
# Mu_1 Mu_2 Mu_3 Mu_4 Mu_5
2e-3 -1e-3 0 0 0
# blank card
# alpha_1 alpha_2 alpha_3 alpha_4 alpha_5
2 -2 0 0 0
# blank card
#enddata
/END
- This
material model defines a hyperelastic, viscous, and incompressible material specified using
the Ogden, Neo-Hookean, or Mooney-Rivlin material models. This law is generally used to
with shell and solid elements.LAW42 uses the following strain energy density representation of the Ogden material model.
(1) Where,- Strain energy density
- ith principal engineering stretch
- Relative volume defined as:
- Deviatoric stretch
- and
- Material constants coefficient pairs.
The initial shear modulus and bulk modulus ( ) are given by:(2) and(3) Where, is the Poisson's ratio and is only used for computing the bulk modulus.
- Parameters
and
must be chosen so that initial shear modulus is
For material stability, it is required that each material constant pair .
- Poisson's ratio
is used only for computing the bulk modulus, Equation 3.
For pure incompressible materials, . This value leads to a finite bulk modulus ( ). Therefore, the recommended maximum Poisson's ratio for incompressible materials is .
Higher values of the Poisson's ratio may lead to a small time step value or divergence in case of implicit and explicit simulations.
- A particular
case of the Ogden material model is the incompressible Mooney-Rivlin model, which can be
represented using the following equation for the strain energy density
function:
(4) Where, and are the first and second invariants of the right Cauchy-Green Tensor.
This representation can be derived from the Ogden strain energy density function when:(5) (6) (7) (8) - A simple case of the Ogden material model
is the Neo-Hookean model represented using the following equation for the strain energy
density function:
(9) Where,- First invariants of the right Cauchy-Green Tensor
- Material constant
This representation can be derived from the LAW42 Ogden strain energy density function when:(10) (11) and(12) - In cases when the bulk modulus of a material is not large enough to prevent compression, LAW42 allows the input of a function (fct_IDblk) which scale the bulk modulus as a function of the relative volume so that the bulk modulus can be increased to maintain incompressibility.
- Viscous (rate) effects are modeled in
LAW42 using a Maxwell model, which can be described in a simplified manner as a system of n
springs with stiffness'
and dampers
Figure 1. Maxwell ModelThe Maxwell model is represented using Prony series inputs ( ). The hyperelastic initial shear modulus is the same as the long-term shear modulus in the Maxwell model, and is the relaxation time:(13) The and values must be positive.
- /VISC/PRONY can be used with this material law to include viscous effects.
