/MAT/LAW35 (FOAM_VISC)
Block Format Keyword This law describes a visco-elastic foam material using Generalized Maxwell-Kelvin-Voigt model where viscosity is based on Navier equations.
This law is applicable only for shell and solid elements and can be used for open cell foams, polymers, elastomers, seat cushions and dummy paddings.
/MAT/LAW35/mat_ID/unit_ID or /MAT/FOAM_VISC/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | E1 | E2 | n | ||||||
C1 | C2 | C3 | IFlag | Pmin | |||||
fct_IDf | Fscaleprs | ||||||||
Et | |||||||||
P0 |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density (Real) |
E | Young's modulus (Real) |
Poisson's ratio (Real) |
E1 | Coefficient for Young's modulus update
. (Real) |
E2 | Coefficient for Young's modulus
update. (Real) |
n | Exponent on relative
volume. (Real) |
C1 | Coefficient for pressure
calculation. (Real) |
C2 | Coefficient for pressure
C3 | Coefficient for pressure
IFlag | Open cell foam flag.
(Integer) |
Pmin | Minimum pressure. (Real) |
fct_IDf | Curve identifier for pressure as
function of volumetric strain volumetric strain is
. (Integer) |
Fscaleprs | Pressure function scale
factor. Default = 1.0 (Real) |
Et | Tangent modulus. (Real) |
Tangent Poisson's
ratio. (Real) |
Viscosity coefficient in pure shear
(Navier's constant). (Real) |
Navier's constant. (Real) |
P0 | Initial air
pressure. (Real) |
Ratio of foam to polymer
density. (Real) |
Initial volumetric
strain. (Real) |
Example (Foam)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/FOAM_VISC/1/1
Foam
# RHO_I
4.3E-11
# E Nu E1 E2 n
.2 0 0 0 0
# C1 C2 C3 Iflag Pmin
1 1 1 0 0
# func_IDf Fscalepres
1076 0
# Et Nu_t eta_0 Lamda
.25 0 10000 0
# P0 Phi gamma_0
0 0 0
#- 3. FUNCTIONS:
/FUNCT/1076
Pressure function
# X Y
# Volumetric strain Pressure
-100000 -1000
-10 -1000
0 0
3000 7.633
209000 7.633
210000 18.5
#ENDDATA
/END
- In all cases, for shear and bulk
modulus calculation, the following value of the Young's modulus will be
used:
(1) - If
fct_IDf =
0,
(2) Where, - If fct_IDf ≠ 0, the pressure is read from curve.
- For closed cell polyurethane
foam, the skeletal spherical stresses may be augmented by:
(3)
