/MAT/LAW34 (BOLTZMAN)
Block Format Keyword This law describes the Boltzmann (visco-elastic) material. This law is applicable only for solid elements and can be used to model polymers and elastomers.
/MAT/LAW34/mat_ID/unit_ID or /MAT/BOLTZMAN/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
K | |||||||||
P0 |
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density (Real) |
K | Bulk
modulus. (Real) |
Short time shear
modulus. (Real) |
Long time shear
modulus. (Real) |
Decay
constant. (Real) |
P0 | Initial air
pressure. (Real) |
Foam versus polymer
density ratio. (Real) |
Initial volumetric
strain. (Real) |
Example (Plastic)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/BOLTZMAN/1/1
plastic
# RHO_I
2E-10
# K
66.67
# G0 Gl Beta
100 100 50000
# P0 Phi Gamma0
0 0 0
#ENDDATA
/END
- For closed cell foam
material, the pressure may be augmented:
(1) With(2) (3) Where,- Volumetric strain
- Porosity
- Initial air pressure
- Initial volumetric strain
- Bulk modulus
- Stress deviator for
viscoelastic material:
(4) While the shear relaxation moduli is:(5) Where,- Long time shear module
- Short time shear module
- Decay constant with
When t = 0, then and then, .
