Mechanism Browser
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
View new features for HyperWorks 2021.1.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Detect, review, and manage geometric holes, fillets, flanges, and logos.
Overview of the Mechanism Browser.
The Entity Editor is used to assign, modify and quickly view the attributes defined inside Mechanism Browser entities.
Create a mechanism for Abaqus, OptiStruct, and Nastran profiles.
Define physical and mathematical characteristics of parts.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
HyperMesh composites modelings.
ON THIS PAGE
ON THIS PAGE
