Airbag Solutions
Restriction: Radioss is the solver currently supported for the Airbag Solutions ribbon. In order to use the folder for other explicit solver use cases, please contact support.
For each of the steps, a solver deck is generated automatically from your selections, such as geometric definition of a fold, target positions of boundary nodes in the stitching and the target container in the housing. You do not need to know any of the solver cards or have strong knowledge about Radioss, however you will have to run the solver deck that is generated.
Once the solver run is finished, you will import the new node positions, and in the stitching the new connectivity, from the .h3d file.
