Design Space
Additional capabilities, such as the non-design space library, collision detection of package space subsystems, and direct access to the most commonly used model build tools and connectivity capabilities provide a complete solution. It’s possible to make design space changes quickly and effectively allowing further exploration of possible variants. In addition, the pedigree of these changes is also preserved.
Restriction: The Design Space ribbon is only available for the OptiStruct solver interface.
