Read .h3d Node Positions
For every task, with the exception of creating a table, once the solver run is finished you will import the new node positions, and in the stitching the new connectivity, from the .h3d file generated.
From the Airbag Solutions ribbon, click the satellite
icon
that appears when you hover over
the tool.
- Enter a File name (.h3d file) and click Open.
