HV-3080: Create Linear Superposition Loadsteps
Learn how to create a linear superposition loadstep from existing loadsteps and contour a linear superposition loadstep.
- Right-click in the Results Browser and select .
OR
- Click the Derived Load Cases button
on the Result toolbar and set the Type to Linear-Superposition.
OR
- Select Type to Linear-Superposition. from the menu bar and set the
![](../../../images/tutorials/hv/hv-3080_pic1.png)
This utility allows you to create linear superposition loadsteps using existing loadsteps and their simulation steps. Linear superposition loadsteps are saved to the session file. Using this utility, you can also create derived loadsteps and envelope loadsteps. See the Derived Load Cases topic for additional information.
