HM-4625: Assemblies Using DYNA
In this tutorial, you will learn how to weld between geometry surfaces and shell elements, welding using a master connectors file and duplicating and reflecting connectors, create connectors from existing welds to create new welds of a different type, swap welded part, and understand why connectors may fail to realize and how to correct the problems.
- frame_assembly_1.hm
- frame_assembly_2.hm
- frame_assembly_3.hm
- frame_assembly_4.hm
- body_side_assembly.hm
