Exercise 2: Weld Using a Master Connectors File and Duplicate and Reflect Connectors
In this exercise, you will becoming familiar with defining weld locations in HyperMesh by importing a master connectors file and Duplicating, reflecting, and updating connectors to create welds.
Third, you will combine adjacent 2T connectors into 3T connectors in order to update adjacent 2T welds to 3T welds.
Retrieve and View the Model File
In this step, you will retrieve and view the model file in HyperMesh.
Create Connectors
In this step, you will create connectors to connect the right rails to each other and to the front trusses by importing a master connectors file.
- From the menu bar, click .
- Set File type to Connectors.
- In the File field, open the rails_frt_truss.mwf file.
- Click Import.
Realize the Connectors into LS-DYNA 100 Mat100 Welds
In this step, you will realize the connectors in the component, CE_Locations, into LS-DYNA 100 Mat100 (beam) welds.
Verify Materials were Automatically Created
In this step, you will verify materials were automatically created when the LS-DYNA 100 Mat100 (beam) welds were created.
Verify Properties were Automatically Created
In this step, you will verify that properties were automatically created when the LS-DYNA 100 Mat100 (beam) welds were created.
Verify a Contact was Automatically Created
In this step, you will verify that a contact was automatically created when the LS-DYNA 100 Mat100 (beam) welds were created.
Display the Rail Components
In this step, you will display the components Left_Rail_1 and Left_Rail_2 for elements.
Duplicate and Reflect the Connectors
In this step, you will duplicate and reflect the connectors created from the master connectors file.
Update the Connectors
In this step, you will update the connectors for the left rails to link them to the left rail components.
Verify Connectors are Realized and Identify Ajacent Connector Pairs
In this step, you will verify that all connectors are realized and identify the pairs of adjacent connectors.
Isolate the Pairs of Adjacent 2t Connectors
In this step, you will isolate the pairs of adjacent, 2t connectors.
Unrealize the Selected Connectors
In this step, you will unrealize the selected connectors.
Save Your Work
In this step, you will save your work in HyperMesh.
