Single Conductor Cable
This option defines a single cable.
Parameters:
- Cross section label
- The label of the cross section.
- Core
- PEC
- Select this option to set the core of the cable to PEC.
- Material label
- The label of the metallic medium (as defined in the DI card) to be used for the core.
- Core radius
- The radius of the core.
- Insulation
- Material label
- Thickness
- The thickness of the material to be used as insulator.
- Cable per-unit-length parameters accuracy
- The Cable per-unit-length parameters accuracy can be increased from Normal (default) to High or Very high.
