Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application that allows you to create models,
get hold of simulation results and model configuration information and much more.
With this card a voltage source is placed at a node between two segments or between a segment and a triangle, ground plane
or polygonal plate. It is mostly used to feed wires attached to plates.
This card realises excitation by a magnetic ring current (TEM-frill) on a segment. It gives an an accurate model of a
coaxial feed, but requires both the inner and outer radii.
This card specifies a voltage source on an edge between two triangles or at a connection between a single triangle and
a PEC ground plane or UTD plate.
This card is used to create a FEM modal excitation, which is the fundamental mode of the associated, infinitely long guided
wave structure of the modal port.
This card inputs data from a .rsd file containing the geometry of a transmission line or PCB structure and the current distribution along this line or
on the PCB for one or more frequencies.
This card defines a uniform electric current filament impressed between two arbitrary points inside of the FEM region (it does not have to coincide with the edges of tetrahedra). This can be used to excite for instance a patch antenna.
This card defines a planar, cylindrical or spherical aperture of measured or calculated field values that is converted
by PREFEKO internally into an equivalent array of electric and magnetic dipoles (A5/A6 cards).
The AS card defines an excitation by means of impressed spherical modes which are either radiating (propagating in positive
r direction to infinity, with r being the radius in a spherical coordinate system) or incident onto a structure (propagating
towards the origin r = 0).
The AW card is a two line card which is used to define a waveguide port excitation. With this card a waveguide port excitation
by an impressed mode on a rectangular, circular, or coaxial waveguide, can be modelled or the impressed travelling modes
in all waveguides of a multi-port network can be imported from a .fim file.
This card defines a ground plane with the reflection coefficient approximation (at z = 0). All computations that follow
this card will include the ground plane.
The CA card is used to define a section of a shielded cable which is used for irradiation (for example, computing induced
currents and voltages at the cable terminals) due to external sources. Transmission line theory is applied, for example,
no need to discretise the cable as with the MoM. A section is defined as a straight part of a cable (one cable can consist of multiple sections).
The CM card is used to couple Feko with the transmission line simulation programs CableMod or CRIPTE or the PCB tool PCBMod to calculate the coupling
of electromagnetic fields into transmission lines. (The AC card is used for the case of radiation by these lines.)
This card controls the export of data to additional ASCII files. For example the currents can be exported to the .out file or S-parameters can be exported to a Touchstone file.
This card can be used to define the frequency dependent or independent material characteristics of a dielectric medium,
metallic medium or an impedance sheet.
The EE card requests an a-posteriori error indicator whereby Feko can test the solution against an unconstrained physical test. The result is to give an indication of the region where
local mesh refinement should be considered.
This card includes the complexities of dielectric environments using special Green's functions. The Green's functions
relates the fields in space to the sources.
This card defines a complex load to any non-radiating network port that is not connected to geometry (that is any non-radiating
network of the type Internal).
This card specifies an offset for the origin of the coordinate system for near and far field calculations. It also facilitates
using only a part of the structure through label selection when calculating fields.
This card defines the phase shift of the excitation between one unit cell and the next for periodic boundary conditions. The unit cell for a PBC calculation is specified with the PE card.
This card defines a skin effect, ohmic losses, dielectric sheet, characterised surface definition, arbitrary user defined
impedance boundary condition on wire segments and surface elements or a dielectric surface impedance approximation. Layered
dielectrics can also be defined.
This card is used to define the dielectric properties of each of the windscreen glass layers. These layers are placed
over the antenna elements by defining the relative position of the top layer to the reference plane.
When meshing a model, you can either use the automatic meshing algorithm to calculate the appropriate mesh settings
or you can specify the mesh sizes. When you specify the mesh sizes, the mesh sizes should adhere to certain guidelines.
Feko integrates with various products within Altair Simulation Products such as HyperStudy. Integration with third-party products is also supported through the powerful scripting and plug-in infrastructure.
Feko creates and uses many different file types. It is useful to know what is stored in the various files and weather they were
created by Feko and if it is safe to delete them. The files are grouped as either native files that have been created by Feko or non-native files that are supported by Feko. Non-native files are often exported by Feko even if the formats are not under the control of the Feko development team.
A list of notes, errors and warnings are provided as reference and to provide more information regarding the reason for
the message and how to resolve the problem in the model.
This card specifies an excitation at an edge between triangular surface
elements.
On the Source/Load tab, in the Sources group,
click the Voltage source
icon. From the drop-down list, click the Voltage on edge (AE) icon.
The location of the feed point and the positive feed direction
are substantially easier to specify than the A7 card. In addition it is possible to specify a
feed edge that contains a number of triangle edges.
Parameters:
New source
A new excitation is defined which replaces all previously defined excitations.
Add to sources
A new excitation is defined which is added to the previously defined excitations.
Excite edge
This specifies how the edge is determined:
between regions with multiple labels
The excitation is placed on the edge between the regions with labels specified
in Negative side and Positive side.
Use the field Maximum number of labels on a side to
increase the number of rows available in the table. The positive source direction
is from the Negative side towards the Positive
side.
connected to ground/UTD
Excite the edges of metallic triangles with the labels specified in the
Negative side or Positive side.
The edges of these triangles are connected to UTD
surfaces or to a PEC ground plane (as specified with a BO or GF card).
of microstrip between two points
This is a special microstrip line feed. The excitation is placed on all edges on
a line between points (previously specified with DP cards). The points are
specified in the Start point of edge and End
point of edge dialogs. A GF card with a conducting ground must be
present.
Note: The dialog layout and visibility of options will differ according to the selection
in the Excite edge group.
Meshed surface represents positive feed side
By default, the feed direction is such that the meshed surface represents the negative
feed side. The vector direction of the current is then towards the UTD or ground. When this option is checked, the feed
orientation is reversed.
Magnitude of source (V)
Magnitude value of the voltage source in V.
Phase of source (degrees)
Phase of the voltage source in degrees.
Reference impedance (Ohm)
The reference impedance of the
excitation is used for S-parameter calculations and is the reference impedance used
for realised gain calculations. It is also the default reference impedance used to
calculate and display the reflection coefficient in POSTFEKO. If this field is empty or 0 in an S-parameter calculation, the value specified
at the SP card is used. For realised gain and reflection coefficient calculations,
50 Ohm will be assumed when the field is empty or 0.
The positive source direction as used above is in the
direction of the current flow through the edge. The internal EMF (electromagnetic force) of
the impressed voltage source is in the opposite direction.
It should be noted that the edge
between the surfaces with labels Negative side and
Positive side does not have to be straight. It is possible, for
example, to excite two half cylinders against each other. If an impedance must also be
applied to the edge, the AE card can be combined with the LE card.
For the case where
the option, between regions with multiple labels, is selected more
than two surfaces may be connected to a feed edge. Examples for this as seen in the figures
are:
one surface fed against three others
two surfaces fed against two other surfaces
and a feeding edge on a junction between three surfaces.
